Nokia Lumia 720 Coaxial Antenna Cable Replacement
Video Overview
  1. Nokia Lumia 720 Coaxial Antenna Cable Replacement, BATTERY COVER - PART 1: step 1, image 1 of 3 Nokia Lumia 720 Coaxial Antenna Cable Replacement, BATTERY COVER - PART 1: step 1, image 2 of 3 Nokia Lumia 720 Coaxial Antenna Cable Replacement, BATTERY COVER - PART 1: step 1, image 3 of 3
    • Remove the SIM card tray and the memory card try.
    • Use a screwdriver Torx T2 and remove the screw under the SIM card tray.
    • Use plastic tools and start the separating the back cover from the top side.
  2. Nokia Lumia 720 Coaxial Antenna Cable Replacement, BATTERY COVER - PART 2: step 2, image 1 of 3 Nokia Lumia 720 Coaxial Antenna Cable Replacement, BATTERY COVER - PART 2: step 2, image 2 of 3 Nokia Lumia 720 Coaxial Antenna Cable Replacement, BATTERY COVER - PART 2: step 2, image 3 of 3
    • Be careful with the volume buttons.
  3. Nokia Lumia 720 Coaxial Antenna Cable Replacement, Loudspeaker & Antenna module: step 3, image 1 of 3 Nokia Lumia 720 Coaxial Antenna Cable Replacement, Loudspeaker & Antenna module: step 3, image 2 of 3 Nokia Lumia 720 Coaxial Antenna Cable Replacement, Loudspeaker & Antenna module: step 3, image 3 of 3
    • Remove the 3x Torx T4 screws.
    • Buzzer / Loudspeacker
  4. Nokia Lumia 720 Coaxial Antenna Cable Replacement, COAXIAL ANTENNA CABLE: step 4, image 1 of 3 Nokia Lumia 720 Coaxial Antenna Cable Replacement, COAXIAL ANTENNA CABLE: step 4, image 2 of 3 Nokia Lumia 720 Coaxial Antenna Cable Replacement, COAXIAL ANTENNA CABLE: step 4, image 3 of 3
    • Disconnect the Antenna cable from the Logic board and from the Charging Dock board and remove it.
ZFix
192,056 Reputation
330 Guides authored
Master Techs Member of Master Techs
Community
321 Members
1,525 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 925
