Nokia Lumia 720 Display Assembly Replacement
Video Overview
  1. Nokia Lumia 720 Display Assembly Replacement, BATTERY COVER - PART 1: step 1, image 1 of 3 Nokia Lumia 720 Display Assembly Replacement, BATTERY COVER - PART 1: step 1, image 2 of 3 Nokia Lumia 720 Display Assembly Replacement, BATTERY COVER - PART 1: step 1, image 3 of 3
    • Remove the SIM card tray and the memory card try.
    • Use a screwdriver Torx T2 and remove the screw under the SIM card tray.
    • Use plastic tools and start the separating the back cover from the top side.
  2. Nokia Lumia 720 Display Assembly Replacement, BATTERY COVER - PART 2: step 2, image 1 of 3 Nokia Lumia 720 Display Assembly Replacement, BATTERY COVER - PART 2: step 2, image 2 of 3 Nokia Lumia 720 Display Assembly Replacement, BATTERY COVER - PART 2: step 2, image 3 of 3
    • Be careful with the volume buttons.
  3. Nokia Lumia 720 Display Assembly Replacement, Loudspeaker & Antenna module: step 3, image 1 of 3 Nokia Lumia 720 Display Assembly Replacement, Loudspeaker & Antenna module: step 3, image 2 of 3 Nokia Lumia 720 Display Assembly Replacement, Loudspeaker & Antenna module: step 3, image 3 of 3
    • Remove the 3x Torx T4 screws.
    • Buzzer / Loudspeacker
  4. Nokia Lumia 720 Display Assembly Replacement, BATTERY: step 4, image 1 of 3 Nokia Lumia 720 Display Assembly Replacement, BATTERY: step 4, image 2 of 3 Nokia Lumia 720 Display Assembly Replacement, BATTERY: step 4, image 3 of 3
    • Disconnect the battery flex cable.
    • Unstick the metal foil from the logic board.
    • Use a plastic tool with a thin tip and unstuck the battery from the middle frame.
    • Battery - BP-4GWA, 2000mAh, 3.7V, 7.4Vh
  5. Nokia Lumia 720 Display Assembly Replacement, COAXIAL ANTENNA CABLE: step 5, image 1 of 3 Nokia Lumia 720 Display Assembly Replacement, COAXIAL ANTENNA CABLE: step 5, image 2 of 3 Nokia Lumia 720 Display Assembly Replacement, COAXIAL ANTENNA CABLE: step 5, image 3 of 3
    • Disconnect the Antenna cable from the Logic board and from the Charging Dock board and remove it.
  6. Nokia Lumia 720 Display Assembly Replacement, Logic Board: step 6, image 1 of 3 Nokia Lumia 720 Display Assembly Replacement, Logic Board: step 6, image 2 of 3 Nokia Lumia 720 Display Assembly Replacement, Logic Board: step 6, image 3 of 3
    • Disconnect the Volume, Power and camera buttons flex cable.
    • Remove the 4x Torx T4 screws.
    • Slightly lift the board
    • Slowly and gently unstuck the light sensor from the middle frame.
  7. Nokia Lumia 720 Display Assembly Replacement: step 7, image 1 of 3 Nokia Lumia 720 Display Assembly Replacement: step 7, image 2 of 3 Nokia Lumia 720 Display Assembly Replacement: step 7, image 3 of 3
    • Disconnect the Display Assembly flex cable.
    • Disconnect the Charging Dock Board flex cable.
    • Remove the Main board.
  8. Nokia Lumia 720 Display Assembly Replacement, Charging Dock and Microphone Module: step 8, image 1 of 3 Nokia Lumia 720 Display Assembly Replacement, Charging Dock and Microphone Module: step 8, image 2 of 3 Nokia Lumia 720 Display Assembly Replacement, Charging Dock and Microphone Module: step 8, image 3 of 3
    • Use a hair dryer and warm the flex cable.
    • Careful unstuck the flex cable from the middle frame.
    • Micro USB connector
    • Microphone
  9. Nokia Lumia 720 Display Assembly Replacement, EARPIECE: step 9, image 1 of 2 Nokia Lumia 720 Display Assembly Replacement, EARPIECE: step 9, image 2 of 2
    • Use a tool with a sharp point and carefully unstuck the earpiece.
  10. Nokia Lumia 720 Display Assembly Replacement, Power, Volume and Camera buttons flex cable: step 10, image 1 of 3 Nokia Lumia 720 Display Assembly Replacement, Power, Volume and Camera buttons flex cable: step 10, image 2 of 3 Nokia Lumia 720 Display Assembly Replacement, Power, Volume and Camera buttons flex cable: step 10, image 3 of 3
    • When you start with the removing the ribbon cable be careful with the buttons and with the small black cups on it.
    • Warm the flex cable and detach it.
  11. Nokia Lumia 720 Display Assembly Replacement, Display Assembly: step 11, image 1 of 3 Nokia Lumia 720 Display Assembly Replacement, Display Assembly: step 11, image 2 of 3 Nokia Lumia 720 Display Assembly Replacement, Display Assembly: step 11, image 3 of 3
    • Now you can start with the reassembling, but before you place the back cover, test the new display assembly.
    • When you put the lid be careful with the volume buttons.
  12. Nokia Lumia 720 Display Assembly Replacement: step 12, image 1 of 1
    • That's all.
    • Did you do it successfully?
5 other people completed this guide.
ZFix
196,706 Reputation
330 Guides authored
Master Techs Member of Master Techs
Community
333 Members
1,479 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 23
All Time: 6,137
