Nokia Lumia 735 Battery Replacement
    • Turn off the device before starting this process
  1. Nokia Lumia 735 Battery Replacement, Remove the Back Cover (Part 1): step 2, image 1 of 3 Nokia Lumia 735 Battery Replacement, Remove the Back Cover (Part 1): step 2, image 2 of 3 Nokia Lumia 735 Battery Replacement, Remove the Back Cover (Part 1): step 2, image 3 of 3
    • Stick your opening pick between the plastic casing and the screen
    • Move your pick up toward the top corner of the phone
    • Rotate the pick so it is parallel with the back of the phone
  2. Nokia Lumia 735 Battery Replacement, Remove the Back Cover (Part 2): step 3, image 1 of 3 Nokia Lumia 735 Battery Replacement, Remove the Back Cover (Part 2): step 3, image 2 of 3 Nokia Lumia 735 Battery Replacement, Remove the Back Cover (Part 2): step 3, image 3 of 3
    • Move the pick in between the back of the phone and the plastic cover to the top left corner
    • Use the gap made by the pick between the back plastic and the phone to pry apart the two parts
    • The back should now be removed exposing the battery, SIM card, and SD card on the back of the phone
  3. Nokia Lumia 735 Battery Replacement, Remove the Battery: step 4, image 1 of 3 Nokia Lumia 735 Battery Replacement, Remove the Battery: step 4, image 2 of 3 Nokia Lumia 735 Battery Replacement, Remove the Battery: step 4, image 3 of 3
    • Insert the pick into the opening near the top of the battery
    • Use the pick to lift up the battery until you can remove it from its resting place
    • The battery should now be removed from the phone
  4. Nokia Lumia 735 Battery Replacement, Adding the New Battery: step 5, image 1 of 2 Nokia Lumia 735 Battery Replacement, Adding the New Battery: step 5, image 2 of 2
    • Insert the new battery bottom first, lining up the connectors on the battery with the connectors on the phone
    • Slide the battery in and push it down so it stays in its place
  5. Nokia Lumia 735 Battery Replacement, Putting Back on the Back: step 6, image 1 of 2 Nokia Lumia 735 Battery Replacement, Putting Back on the Back: step 6, image 2 of 2
    • Line up the back with the back of the phone
    • Push down on the back until you hear it snap into place
    • Congratulations! You just replaced the battery on your phone, you may turn it back on and begin using it normally.
Daniel Stark
168 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 5
All Time: 287
