Nokia Lumia 925 Motherboard Replacement
  1. Nokia Lumia 925 Motherboard Replacement, Motherboard: step 1, image 1 of 2 Nokia Lumia 925 Motherboard Replacement, Motherboard: step 1, image 2 of 2
    Tool used on this step:
    Buy
    • Remove the sim card holder by inserting tweezers into the hole. Push down and the holder will spring back up.
    • Pull out the holder until it is completely separate.
    • Something like a paperclip will work if there are no tweezers available.
  2. Nokia Lumia 925 Motherboard Replacement: step 2, image 1 of 3 Nokia Lumia 925 Motherboard Replacement: step 2, image 2 of 3 Nokia Lumia 925 Motherboard Replacement: step 2, image 3 of 3
    • Slide a plastic opening tool under the back cover.
    • Slide the tool around the outsides of the cover to fully dislodge the pins holding the cover to the phone.
    • Some pins are facing the opposite way from the others.
  3. Nokia Lumia 925 Motherboard Replacement: step 3, image 1 of 3 Nokia Lumia 925 Motherboard Replacement: step 3, image 2 of 3 Nokia Lumia 925 Motherboard Replacement: step 3, image 3 of 3
    • Remove the 3 screws using the T7 Torx screwdriver.
    • Unclip the black tab connector.
  4. Nokia Lumia 925 Motherboard Replacement: step 4, image 1 of 2 Nokia Lumia 925 Motherboard Replacement: step 4, image 2 of 2
    • Remove the silver metal cover.
    • Be careful of the tape under the right square side of the panel. Using a spudger helps.
  5. Nokia Lumia 925 Motherboard Replacement: step 5, image 1 of 3 Nokia Lumia 925 Motherboard Replacement: step 5, image 2 of 3 Nokia Lumia 925 Motherboard Replacement: step 5, image 3 of 3
    • Unclip the two orange tabs.
    • Remove the four silver screws using the T5 Torx screwdriver.
  6. Nokia Lumia 925 Motherboard Replacement: step 6, image 1 of 2 Nokia Lumia 925 Motherboard Replacement: step 6, image 2 of 2
    • Remove the motherboard by sliding tweezers between it and the back of the screen. Lift up.
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 8
All Time: 787
