Nokia N70 Battery Replacement
  1. Nokia N70 Battery Replacement, Battery: step 1, image 1 of 1
    • Orient the phone as shown.
    • Press the button with the plastic opening tool and slide the back case downward relative to the phone.
  2. Nokia N70 Battery Replacement: step 2, image 1 of 1
    • Remove the battery cover by lifting it away from the phone.
  3. Nokia N70 Battery Replacement: step 3, image 1 of 1
    • Insert the plastic opening tool into the marked space.
    • Lift up the side of the battery closest to the bottom edge of the phone using the plastic opening tool.
  4. Nokia N70 Battery Replacement: step 4, image 1 of 1
    • Remove the battery from the phone.
5 other people completed this guide.
Justin
1,026 Reputation
5 Guides authored
Cal Poly, Team 6-2, Regan Fall 2011 Member of Cal Poly, Team 6-2, Regan Fall 2011
CPSU-REGAN-F11S6G2
4 Members
11 Guides authored
1 Guide Comment
A recherche batterie et chargeur Nokia N 70,merci.
abd.atif - Reply
Past 24 Hours: 3
Past 7 Days: 22
Past 30 Days: 72
All Time: 10,866
