Nokia N70 Keypad Replacement
  1. Nokia N70 Keypad Replacement, Battery: step 1, image 1 of 1
    • Orient the phone as shown.
    • Press the button with the plastic opening tool and slide the back case downward relative to the phone.
  2. Nokia N70 Keypad Replacement: step 2, image 1 of 1
    • Remove the battery cover by lifting it away from the phone.
  3. Nokia N70 Keypad Replacement: step 3, image 1 of 1
    • Insert the plastic opening tool into the marked space.
    • Lift up the side of the battery closest to the bottom edge of the phone using the plastic opening tool.
  4. Nokia N70 Keypad Replacement: step 4, image 1 of 1
    • Remove the battery from the phone.
  5. Nokia N70 Keypad Replacement, Keypad: step 5, image 1 of 3 Nokia N70 Keypad Replacement, Keypad: step 5, image 2 of 3 Nokia N70 Keypad Replacement, Keypad: step 5, image 3 of 3
    • Insert the plastic opening tool in the marked areas in between the front and back covers.
    • Pry each corner with the plastic opening tool until the front case completely detaches.
  6. Nokia N70 Keypad Replacement: step 6, image 1 of 3 Nokia N70 Keypad Replacement: step 6, image 2 of 3 Nokia N70 Keypad Replacement: step 6, image 3 of 3
    • Orient the phone so that the keypad is facing you.
    • Remove the keypad by lifting it away from the phone.
Justin
1,026 Reputation
5 Guides authored
Cal Poly, Team 6-2, Regan Fall 2011 Member of Cal Poly, Team 6-2, Regan Fall 2011
CPSU-REGAN-F11S6G2
4 Members
11 Guides authored
1 Guide Comment
I have N70 nokia mobile. Its keypad buttons 1, 2 & C and also left key and upper key is not working
please give me solution how to solve this problem
Imamuddin - Reply
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 25
All Time: 4,258
