Nokia N900 Slider Assembly Replacement
  1. Nokia N900 Slider Assembly Replacement, Slider Assembly: step 1, image 1 of 1
    • Turn the phone over so the screen is face down.
  2. Nokia N900 Slider Assembly Replacement: step 2, image 1 of 2 Nokia N900 Slider Assembly Replacement: step 2, image 2 of 2
    • Remove the back cover by locating the slit on the bottom of the phone and lifting up.
  3. Nokia N900 Slider Assembly Replacement: step 3, image 1 of 1
    • Remove the battery by lifting it out of the device.
  4. Nokia N900 Slider Assembly Replacement: step 4, image 1 of 2 Nokia N900 Slider Assembly Replacement: step 4, image 2 of 2
    • Remove the two "L-shaped" antennas by unscrewing the following screws:
    • Four screw M1 .4x5.0
    • Two screw RF1 .4x4
    • In addition to unscrewing the screws, remove the B-Cover (which will fall right out without the screws).
  5. Nokia N900 Slider Assembly Replacement: step 5, image 1 of 1
    • Turn the back of the phone over so the keyboard is face up. You should then have two halves of the phone.
    • To locate the slider, find the "black tape" on the screen half of the phone.
    • Weave the "slider tape" through the orange slot on the keyboard half of the phone.
    • Once you have completed these steps your phone should be able to slide up and down with ease.
Troy Posey
349 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 3
All Time: 1,032
