Nokia X USB Port Replacement
  1. Nokia X USB Port Replacement, Nokia X Disassembly Prerequisites: step 1, image 1 of 1
    • Remove the back cover of the device by applying light pressure toward the outer rim and display.
  2. Nokia X USB Port Replacement: step 2, image 1 of 1
    • Remove 7 (size 4 M1 4*3.5) and 4(size 6 M2 6*4.5) screws using P5 hex screwdriver.
    • The M2 screws are shown in red.
    • The M1 screws are shown in orange.
  3. Nokia X USB Port Replacement: step 3, image 1 of 1
    • Gently separate the display from the chassis.
    • Slowly spread the display and chassis until the inside of the device is reachable.
    • Do not pull apart.
  4. Nokia X USB Port Replacement: step 4, image 1 of 1
    Tool used on this step:
    Spudger
    $2.99
    Buy
    • Using the spudger tool, release the top flex ribbon from the light swap package.
  5. Nokia X USB Port Replacement, USB Port: step 5, image 1 of 2 Nokia X USB Port Replacement, USB Port: step 5, image 2 of 2
    • Again, using a spudger tool, release the rear facing camera from the light swap display.
    • Carefully remove the light swap display from the chassis by applying pressure to the circuit board.
  6. Nokia X USB Port Replacement: step 6, image 1 of 1
    • Using a soldering iron, desolder they broken USB port.
    • Solder your replacement USB port onto the light swap package.
6 other people completed this guide.
Josh Perino
436 Reputation
2 Guides authored
IUPUI, Team S7-G7, Wilson Spring 2017 Member of IUPUI, Team S7-G7, Wilson Spring 2017
IUPUI-WILSON-S17S7G7
3 Members
8 Guides authored
1 Guide Comment
my mobile usb port no pls replacement
Giri GOWDA Nature RIDER - Reply
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 7
All Time: 1,556
