Nokia XL Dual SIM Touch Screen, Volume Buttons, and Power/Screen Lock button Replacement
  1. Nokia XL Dual SIM Touch Screen, Volume Buttons, and Power/Screen Lock button Replacement, Back Cover Removal: step 1, image 1 of 1
    • You will first need to separate the back cover from the device.
    • Gently pry open each side of the device at the indicated locations. It is best to use a plastic opening tool or similar tool.
  2. Nokia XL Dual SIM Touch Screen, Volume Buttons, and Power/Screen Lock button Replacement, Battery Removal: step 2, image 1 of 2 Nokia XL Dual SIM Touch Screen, Volume Buttons, and Power/Screen Lock button Replacement, Battery Removal: step 2, image 2 of 2
    • Remove the back cover.
    • Use a plastic opening tool to lift the battery. Then, remove it.
  3. Nokia XL Dual SIM Touch Screen, Volume Buttons, and Power/Screen Lock button Replacement, Screen Separation part 1: step 3, image 1 of 2 Nokia XL Dual SIM Touch Screen, Volume Buttons, and Power/Screen Lock button Replacement, Screen Separation part 1: step 3, image 2 of 2
    • To access the inner components of the device, remove the various screws. Keep them separate, and organize them by size.
    • You will need a T5 Precision Torx screw driver to remove the screws.
    • The locations of the T5x3.4mm screws are indicated in the picture.
    • The locations of the T5x4.1mm screws are indicated in the picture.
  4. Nokia XL Dual SIM Touch Screen, Volume Buttons, and Power/Screen Lock button Replacement, Screen Separation part 2: step 4, image 1 of 3 Nokia XL Dual SIM Touch Screen, Volume Buttons, and Power/Screen Lock button Replacement, Screen Separation part 2: step 4, image 2 of 3 Nokia XL Dual SIM Touch Screen, Volume Buttons, and Power/Screen Lock button Replacement, Screen Separation part 2: step 4, image 3 of 3
    • Use the plastic opening tool to gently pry the device apart.
    • There are flaps on both sides of the phone as indicated in the picture. This is what you will need to pry apart.
    • Please be cautious when opening the device. There are various connectors inside the device that must be handled with care.
  5. Nokia XL Dual SIM Touch Screen, Volume Buttons, and Power/Screen Lock button Replacement, System components: step 5, image 1 of 1
    • Once the device is open, take note of all the components.
  6. Nokia XL Dual SIM Touch Screen, Volume Buttons, and Power/Screen Lock button Replacement, Remove motherboard connectors: step 6, image 1 of 3 Nokia XL Dual SIM Touch Screen, Volume Buttons, and Power/Screen Lock button Replacement, Remove motherboard connectors: step 6, image 2 of 3 Nokia XL Dual SIM Touch Screen, Volume Buttons, and Power/Screen Lock button Replacement, Remove motherboard connectors: step 6, image 3 of 3
    Tool used on this step:
    Buy
    • Gently unsnap the 3 motherboard connectors for the touch screen assembly with tweezers.
    • The touch screen, volume buttons, and power/screen lock button assembly can now be removed.
16 other people completed this guide.
Christopher Weaver
984 Reputation
2 Guides authored
USF Tampa, Team 1-4, Brown Fall 2014 Member of USF Tampa, Team 1-4, Brown Fall 2014
USFT-BROWN-F14S1G4
3 Members
7 Guides authored
One Comment
next pic i whant this information touch change....
prakash prakash - Reply
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 5
All Time: 16,056
