Nokia XL Dual Sim Battery Replacement
  1. Nokia XL Dual Sim Battery Replacement, Replacing the battery: step 1, image 1 of 3 Nokia XL Dual Sim Battery Replacement, Replacing the battery: step 1, image 2 of 3 Nokia XL Dual Sim Battery Replacement, Replacing the battery: step 1, image 3 of 3
    • Shut off the device completely.
    • Separate the back cover from the device by gently prying the opening out at the loose locations.
    • Gently pry open each side of the device at the indicated locations. It is best to use a plastic opening tool or similar item.
  2. Nokia XL Dual Sim Battery Replacement, Battery Removal: step 2, image 1 of 2 Nokia XL Dual Sim Battery Replacement, Battery Removal: step 2, image 2 of 2
    • Once the back cover is removed, the battery will be in plain sight.
    • Again, use the plastic opening tool to lift the battery. From there, you can simply remove it.
  3. Nokia XL Dual Sim Battery Replacement: step 3, image 1 of 1
    • You will now take your new battery and insert it into its designated location. Make sure to look at the position the battery was in before you took it out so you don't damage any of it's important parts.
    • Please be aware that your new battery may need to be charged first in order for your device to power back on.
2 other people completed this guide.
Shadeed Bilal
231 Reputation
4 Guides authored
USF Tampa, Team 1-4, Brown Fall 2014 Member of USF Tampa, Team 1-4, Brown Fall 2014
USFT-BROWN-F14S1G4
3 Members
7 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 18
All Time: 2,526
