Nokia XL Dual Sim Rear Camera Replacement
  1. Nokia XL Dual Sim Rear Camera Replacement, Back Cover Removal: step 1, image 1 of 1
    • You will first need to separate the back cover from the device.
    • Gently pry open each side of the device at the indicated locations. It is best to use a plastic opening tool or similar tool.
  2. Nokia XL Dual Sim Rear Camera Replacement, Battery Removal: step 2, image 1 of 2 Nokia XL Dual Sim Rear Camera Replacement, Battery Removal: step 2, image 2 of 2
    • Remove the back cover.
    • Use a plastic opening tool to lift the battery. Then, remove it.
  3. Nokia XL Dual Sim Rear Camera Replacement, Screen Separation part 1: step 3, image 1 of 2 Nokia XL Dual Sim Rear Camera Replacement, Screen Separation part 1: step 3, image 2 of 2
    • To access the inner components of the device, remove the various screws. Keep them separate, and organize them by size.
    • You will need a T5 Precision Torx screw driver to remove the screws.
    • The locations of the T5x3.4mm screws are indicated in the picture.
    • The locations of the T5x4.1mm screws are indicated in the picture.
  4. Nokia XL Dual Sim Rear Camera Replacement, Screen Separation part 2: step 4, image 1 of 3 Nokia XL Dual Sim Rear Camera Replacement, Screen Separation part 2: step 4, image 2 of 3 Nokia XL Dual Sim Rear Camera Replacement, Screen Separation part 2: step 4, image 3 of 3
    • Use the plastic opening tool to gently pry the device apart.
    • There are flaps on both sides of the phone as indicated in the picture. This is what you will need to pry apart.
    • Please be cautious when opening the device. There are various connectors inside the device that must be handled with care.
  5. Nokia XL Dual Sim Rear Camera Replacement, System components: step 5, image 1 of 1
    • Once the device is open, take note of all the components.
  6. Nokia XL Dual Sim Rear Camera Replacement, Camera Removal Pt. 1: step 6, image 1 of 2 Nokia XL Dual Sim Rear Camera Replacement, Camera Removal Pt. 1: step 6, image 2 of 2
    Tool used on this step:
    Buy
    • With tweezers, gently release the rear camera motherboard connector.
  7. Nokia XL Dual Sim Rear Camera Replacement, Camera Removal Pt. 2: step 7, image 1 of 3 Nokia XL Dual Sim Rear Camera Replacement, Camera Removal Pt. 2: step 7, image 2 of 3 Nokia XL Dual Sim Rear Camera Replacement, Camera Removal Pt. 2: step 7, image 3 of 3
    • Gently pull the motherboard connector upward to remove the rear camera component.
Shadeed Bilal
231 Reputation
4 Guides authored
USF Tampa, Team 1-4, Brown Fall 2014 Member of USF Tampa, Team 1-4, Brown Fall 2014
USFT-BROWN-F14S1G4
3 Members
7 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 15
All Time: 912
