Nook BNRV300 Back Cover Replacement
  1. Nook BNRV300 Back Cover Replacement, Power Button: step 1, image 1 of 3 Nook BNRV300 Back Cover Replacement, Power Button: step 1, image 2 of 3 Nook BNRV300 Back Cover Replacement, Power Button: step 1, image 3 of 3
    • Power off your Nook before working on your device. Hold the power button for about 5 seconds and select the “Power Off” option.
    • Turn the Nook over to find the power button along the back upper edge.
    • Wedge the spudger between the top of the power button and the upper edge of the device.
    • Push the tool down to pry the button up and off.
  2. Nook BNRV300 Back Cover Replacement: step 2, image 1 of 1
    • Using your fingers, take off the power button.
  3. Nook BNRV300 Back Cover Replacement, Back Cover: step 3, image 1 of 3 Nook BNRV300 Back Cover Replacement, Back Cover: step 3, image 2 of 3 Nook BNRV300 Back Cover Replacement, Back Cover: step 3, image 3 of 3
    • Peel off the white sticker that is covering the screw head.
    • Remove the one 2mm-long screw using a size T5 Torx screwdriver.
  4. Nook BNRV300 Back Cover Replacement: step 4, image 1 of 1
    • Slide the back cover down towards the USB port to release it. The pictures show the case being pried open but this should not be necessary.
  5. Nook BNRV300 Back Cover Replacement: step 5, image 1 of 3 Nook BNRV300 Back Cover Replacement: step 5, image 2 of 3 Nook BNRV300 Back Cover Replacement: step 5, image 3 of 3
    • Use a spudger or your fingers to gently pry the connector out of the white socket.
    • The back cover is now fully detached.
  6. Nook BNRV300 Back Cover Replacement: step 6, image 1 of 2 Nook BNRV300 Back Cover Replacement: step 6, image 2 of 2
    Tool used on this step:
    Buy
    • Use tweezers to remove the brass-colored threaded fastener from the Nook plastic casing.
3 other people completed this guide.
1 Guide Comment
Check the comments on each step. There are some adjustments to the process to properly and safely take this apart.
dl200010 - Reply
Past 24 Hours: 2
Past 7 Days: 12
Past 30 Days: 57
All Time: 1,808
