Nook BNRV300 Power Button Replacement
  1. Nook BNRV300 Power Button Replacement, Power Button: step 1, image 1 of 3 Nook BNRV300 Power Button Replacement, Power Button: step 1, image 2 of 3 Nook BNRV300 Power Button Replacement, Power Button: step 1, image 3 of 3
    • Power off your Nook before working on your device. Hold the power button for about 5 seconds and select the “Power Off” option.
    • Turn the Nook over to find the power button along the back upper edge.
    • Wedge the spudger between the top of the power button and the upper edge of the device.
    • Push the tool down to pry the button up and off.
  2. Nook BNRV300 Power Button Replacement: step 2, image 1 of 1
    • Using your fingers, take off the power button.
2 Guide Comments
My power button is not responding. Presumably I have to let the power drain because it won't shut off. Do i replace the button or the sensor beneath it?
Lydia Rice - Reply
Check the comments on each step. There are some adjustments to the process to properly and safely take this apart.
dl200010 - Reply
Past 24 Hours: 2
Past 7 Days: 6
Past 30 Days: 31
All Time: 1,134
