Nook Color Battery Replacement
  1. Nook Color Battery Replacement, Back Cover: step 1, image 1 of 2 Nook Color Battery Replacement, Back Cover: step 1, image 2 of 2
    • Remove the two 3.8 mm screws located in the back right corner of the device using the T5 Torx screwdriver.
  2. Nook Color Battery Replacement: step 2, image 1 of 2 Nook Color Battery Replacement: step 2, image 2 of 2
    • Pry off the back cover with the plastic opening tool. Go around the device with the tool to ensure complete detachment.
  3. Nook Color Battery Replacement, Front Cover: step 3, image 1 of 1
    • Remove the ten 4.0 mm screws from the device's perimeter using the T5 Torx screwdriver.
  4. Nook Color Battery Replacement: step 4, image 1 of 2 Nook Color Battery Replacement: step 4, image 2 of 2
    • Pry off the front panel using the plastic opening tool.
  5. Nook Color Battery Replacement: step 5, image 1 of 2 Nook Color Battery Replacement: step 5, image 2 of 2
    • Lift up on the connectors to disconnect them using the plastic opening tool.
  6. Nook Color Battery Replacement, Battery: step 6, image 1 of 2 Nook Color Battery Replacement, Battery: step 6, image 2 of 2
    • Remove the tape which holds the wiring to the battery using a plastic opening tool.
  7. Nook Color Battery Replacement: step 7, image 1 of 3 Nook Color Battery Replacement: step 7, image 2 of 3 Nook Color Battery Replacement: step 7, image 3 of 3
    • On the back side of the middle panel, pry the battery using the plastic opening tools.
    • Use of force is necessary since the battery is glued down.
  8. Nook Color Battery Replacement: step 8, image 1 of 2 Nook Color Battery Replacement: step 8, image 2 of 2
    • Slide the connecting wire through the opening of where the battery was placed.
5 other people completed this guide.
John Goly
508 Reputation
3 Guides authored
USF Tampa, Team 11-5, Blackwell Winter 2015 Member of USF Tampa, Team 11-5, Blackwell Winter 2015
USFT-BLACKWELL-W15S11G5
3 Members
14 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 7
Past 30 Days: 24
All Time: 3,270
