Nook Color Display Replacement
  1. Nook Color Display Replacement, Back Cover: step 1, image 1 of 2 Nook Color Display Replacement, Back Cover: step 1, image 2 of 2
    • Remove the two 3.8 mm screws located in the back right corner of the device using the T5 Torx screwdriver.
  2. Nook Color Display Replacement: step 2, image 1 of 2 Nook Color Display Replacement: step 2, image 2 of 2
    • Pry off the back cover with the plastic opening tool. Go around the device with the tool to ensure complete detachment.
  3. Nook Color Display Replacement, Front Cover: step 3, image 1 of 1
    • Remove the ten 4.0 mm screws from the device's perimeter using the T5 Torx screwdriver.
  4. Nook Color Display Replacement: step 4, image 1 of 2 Nook Color Display Replacement: step 4, image 2 of 2
    • Pry off the front panel using the plastic opening tool.
  5. Nook Color Display Replacement: step 5, image 1 of 2 Nook Color Display Replacement: step 5, image 2 of 2
    • Lift up on the connectors to disconnect them using the plastic opening tool.
  6. Nook Color Display Replacement, Motherboard: step 6, image 1 of 3 Nook Color Display Replacement, Motherboard: step 6, image 2 of 3 Nook Color Display Replacement, Motherboard: step 6, image 3 of 3
    • Gently lift and peel the orange and grey ribbon connectors to disconnect the screen and motherboard.
  7. Nook Color Display Replacement: step 7, image 1 of 1
    • Remove the easy-to-miss T5 Torx 3.8 mm screw located in the tabbed corner of the device.
  8. Nook Color Display Replacement: step 8, image 1 of 2 Nook Color Display Replacement: step 8, image 2 of 2
    • Lift the motherboard gently from the side with the larger connector ribbon.
    • Slide the white cable gently from underneath its holding place to free the motherboard completely.
    • Remove the motherboard carefully from the device.
  9. Nook Color Display Replacement, Display: step 9, image 1 of 3 Nook Color Display Replacement, Display: step 9, image 2 of 3 Nook Color Display Replacement, Display: step 9, image 3 of 3
    • Use a plastic opening tool to gently pry the display upwards.
    • Lift the display out with your hands until the display has separated from the frame.
7 other people completed this guide.
Matthew Perdomo
509 Reputation
3 Guides authored
USF Tampa, Team 11-5, Blackwell Winter 2015 Member of USF Tampa, Team 11-5, Blackwell Winter 2015
USFT-BLACKWELL-W15S11G5
3 Members
14 Guides authored
1 Guide Comment
this site doesn't sell the Nook Color display. Where did you get yours?
Suzette Garoutte - Reply
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 18
All Time: 4,016
