Nook HD+ Antenna Replacement
  1. Nook HD+ Antenna Replacement, Antenna: step 1, image 1 of 1
    • Pry the front frame off of the nook by wedging the plastic opening piece between the frame and the nook.
  2. Nook HD+ Antenna Replacement, Remove the screws: step 2, image 1 of 2 Nook HD+ Antenna Replacement, Remove the screws: step 2, image 2 of 2
    • Remove every visible screw from the front of the nook using the T-4 attachment for the screwdriver in the iFixit screwdriver kit.
  3. Nook HD+ Antenna Replacement, Remove the chassis: step 3, image 1 of 2 Nook HD+ Antenna Replacement, Remove the chassis: step 3, image 2 of 2
    • Carefully remove the center chassis from the bottom frame.
  4. Nook HD+ Antenna Replacement, Dettatch battery: step 4, image 1 of 3 Nook HD+ Antenna Replacement, Dettatch battery: step 4, image 2 of 3 Nook HD+ Antenna Replacement, Dettatch battery: step 4, image 3 of 3
    • Detach the battery ribbon from the motherboard.
  5. Nook HD+ Antenna Replacement, Flip the center chassis: step 5, image 1 of 1
    • Flip the center chassis so that the screen is facing down, and the hole is positioned in the bottom right corner.
  6. Nook HD+ Antenna Replacement, Remove the antenna part 1: step 6, image 1 of 2 Nook HD+ Antenna Replacement, Remove the antenna part 1: step 6, image 2 of 2
    • Remove the wire from the attachment on the motherboard (this wire un-clips).
  7. Nook HD+ Antenna Replacement, Remove the antenna part 2: step 7, image 1 of 2 Nook HD+ Antenna Replacement, Remove the antenna part 2: step 7, image 2 of 2
    • Apply soldering iron to the wire where it connects on the frame side. Remove wire when the solder is molten.
  8. Nook HD+ Antenna Replacement, Place new antenna.: step 8, image 1 of 2 Nook HD+ Antenna Replacement, Place new antenna.: step 8, image 2 of 2
    • Replace new antenna following all the steps in reverse.
Elijah Gonsalves
1,049 Reputation
3 Guides authored
UMass Dartmouth, Team 2-3, Duarte Fall 2014 Member of UMass Dartmouth, Team 2-3, Duarte Fall 2014
UMASSD-DUARTE-F14S2G3
5 Members
10 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 9
All Time: 1,251
