Nook HD+ Battery Replacement
  1. Nook HD+ Battery Replacement, Remove the front frame: step 1, image 1 of 3 Nook HD+ Battery Replacement, Remove the front frame: step 1, image 2 of 3 Nook HD+ Battery Replacement, Remove the front frame: step 1, image 3 of 3
    • Wedge the plastic opening piece underneath the bottom left hand corner of the front frame. Pry the frame off of the Nook.
  2. Nook HD+ Battery Replacement, Remove the screws: step 2, image 1 of 2 Nook HD+ Battery Replacement, Remove the screws: step 2, image 2 of 2
    • Remove every visible screw tying the chassis to the bottom frame using the T-4 attachment for the screwdriver in the iFixit screwdriver kit.
  3. Nook HD+ Battery Replacement, Remove the chassis: step 3, image 1 of 1
    • Carefully remove center chassis from bottom frame.
  4. Nook HD+ Battery Replacement, Detach battery: step 4, image 1 of 3 Nook HD+ Battery Replacement, Detach battery: step 4, image 2 of 3 Nook HD+ Battery Replacement, Detach battery: step 4, image 3 of 3
    • Detach the battery ribbon from the motherboard.
  5. Nook HD+ Battery Replacement, Remove the battery: step 5, image 1 of 2 Nook HD+ Battery Replacement, Remove the battery: step 5, image 2 of 2
    • Pry battery off of bottom frame using plastic opening tool.
  6. Nook HD+ Battery Replacement, Place new battery: step 6, image 1 of 1
    • Apply glue to the bottom side of new battery. Re-insert new battery onto bottom frame and allow to dry. Follow steps in reverse to put nook back together.
12 other people completed this guide.
Elijah Gonsalves
1,049 Reputation
3 Guides authored
UMass Dartmouth, Team 2-3, Duarte Fall 2014 Member of UMass Dartmouth, Team 2-3, Duarte Fall 2014
UMASSD-DUARTE-F14S2G3
5 Members
10 Guides authored
6 Guide Comments
Does model affect battery type? The replacement battery was stated so I'm just curious
Jon - Reply
Where i can buy new battery, or any similar [6000 mAh] ?
Sebastian kukosh - Reply
Anyone have a lead on good batteries?
omarhani - Reply
clear directions, liked this guide
wandat100 - Reply
i have a Barnes and noble nook HD+ and how it won't charger at all.
Tina Brown - Reply
Past 24 Hours: 2
Past 7 Days: 3
Past 30 Days: 36
All Time: 10,178
