Nook HD Back and Front Casing Replacement
  1. Nook HD Back and Front Casing Replacement, Case: step 1, image 1 of 3 Nook HD Back and Front Casing Replacement, Case: step 1, image 2 of 3 Nook HD Back and Front Casing Replacement, Case: step 1, image 3 of 3
    • Be sure the device is powered off. Clean the device to prevent any dirt and dust from entering into the device.
    • Use the plastic opening tool to gently pry the plastic screen frame away from the screen. Run the plastic opening tool along the interior edge of the screen until the screen frame is completely separated from the glass.
    • The screen frame is held onto the Nook by a set of tab that run around the outside of the frame. There may also be a line of rubber cement around the Nook under the screen frame. If your Nook has this, you will have to dig deep to separate the frame from the Nook.
  2. Nook HD Back and Front Casing Replacement: step 2, image 1 of 2 Nook HD Back and Front Casing Replacement: step 2, image 2 of 2
    • Use a T5 screwdriver to remove the seventeen 5.0 millimeter screws from the back casing.
  3. Nook HD Back and Front Casing Replacement: step 3, image 1 of 3 Nook HD Back and Front Casing Replacement: step 3, image 2 of 3 Nook HD Back and Front Casing Replacement: step 3, image 3 of 3
    • Slowly pull the back casing away from the screen and motherboard.
    • There is a cable attaching the battery in the back plate to the motherboard. Avoid detaching either end of the cable during this step.
  4. Nook HD Back and Front Casing Replacement: step 4, image 1 of 3 Nook HD Back and Front Casing Replacement: step 4, image 2 of 3 Nook HD Back and Front Casing Replacement: step 4, image 3 of 3
    • Use the plastic opening tool to gently unclip the wire from the pins by pulling the white connector up.
6 other people completed this guide.
Connor Pickert
320 Reputation
2 Guides authored
Cal Poly, Team 3-43, Maness Spring 2014 Member of Cal Poly, Team 3-43, Maness Spring 2014
CPSU-MANESS-S14S3G43
5 Members
10 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 22
All Time: 2,776
