Nostalgia Chocolate Fondue Fountain CFF965 Baseplate and Switch Replacement
  1. Nostalgia Chocolate Fondue Fountain CFF965 Baseplate and Switch Replacement, Tiered Tower: step 1, image 1 of 1
    • Lift the tiered tower from the base bowl.
  2. Nostalgia Chocolate Fondue Fountain CFF965 Baseplate and Switch Replacement, Auger: step 2, image 1 of 2 Nostalgia Chocolate Fondue Fountain CFF965 Baseplate and Switch Replacement, Auger: step 2, image 2 of 2
    • Use your hands to lift up the auger (the long black metal spiral) away from the base bowl.
  3. Nostalgia Chocolate Fondue Fountain CFF965 Baseplate and Switch Replacement, Baseplate and Switch: step 3, image 1 of 1
    • Flip over the device so that the bowl is now face down.
    • Use your hands to unscrew both 21.3mm screws.
  4. Nostalgia Chocolate Fondue Fountain CFF965 Baseplate and Switch Replacement: step 4, image 1 of 3 Nostalgia Chocolate Fondue Fountain CFF965 Baseplate and Switch Replacement: step 4, image 2 of 3 Nostalgia Chocolate Fondue Fountain CFF965 Baseplate and Switch Replacement: step 4, image 3 of 3
    • Unscrew all three 14.2 mm screws with a Phillips #2 screwdriver.
    • Unscrew the 9.1 mm screw near the switch with a Phillips #2 screwdriver.
    • Unscrew the two 14.2 mm spanner screws using a spanner screwdriver (size 6).
  5. Nostalgia Chocolate Fondue Fountain CFF965 Baseplate and Switch Replacement: step 5, image 1 of 2 Nostalgia Chocolate Fondue Fountain CFF965 Baseplate and Switch Replacement: step 5, image 2 of 2
    • Use your hands to pull up on the baseplate to remove it.
    • Pull the panel with the switch on it upwards.
Kristen Gismondi
84,844 Reputation
215 Guides authored
iFixit Member of iFixit
Staff
141 Members
17,893 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 10
All Time: 431
