Novation Launchkey mini Mk3 / FLkey mini Disassembly
  1. Novation Launchkey mini Mk3 / FLkey mini Disassembly, The entry: step 1, image 1 of 2 Novation Launchkey mini Mk3 / FLkey mini Disassembly, The entry: step 1, image 2 of 2
    • This manual goes for both Lauchkey mini MK3 and FLkey, as they are similar in build.
    • Flipping it upside down, shows 4 screws. After removing these screws, the whole thing still feels just as rigid.
  2. Novation Launchkey mini Mk3 / FLkey mini Disassembly, The breaking: step 2, image 1 of 2 Novation Launchkey mini Mk3 / FLkey mini Disassembly, The breaking: step 2, image 2 of 2
    • Next up are the clippings. I found that starting at a corner works best for me. Then carfully with a pick or screwdriver work yourway around.
    • There's 4 clips on the long sides and 3 on the short sides. Be careful not to open up after undoing all clips.
  3. Novation Launchkey mini Mk3 / FLkey mini Disassembly, The split: step 3, image 1 of 2 Novation Launchkey mini Mk3 / FLkey mini Disassembly, The split: step 3, image 2 of 2
    • When all clips are undone, and the top and bottom shells are lose, carefully lift the back a little and then slide the top shell towards the key-bed.
    • Carefully flip the top and undo the ribbon cable connecting the key-bed with the top shell.
  4. Novation Launchkey mini Mk3 / FLkey mini Disassembly, The keyboard: step 4, image 1 of 3 Novation Launchkey mini Mk3 / FLkey mini Disassembly, The keyboard: step 4, image 2 of 3 Novation Launchkey mini Mk3 / FLkey mini Disassembly, The keyboard: step 4, image 3 of 3
    • The keyboard is undone by unscrewing 9 screws. The keys can then be wiggled out.
    • Mind that the rubber strip has a short and long feet. The short one goes to the front of the board.
  5. Novation Launchkey mini Mk3 / FLkey mini Disassembly, The same suspects: step 5, image 1 of 2 Novation Launchkey mini Mk3 / FLkey mini Disassembly, The same suspects: step 5, image 2 of 2
    • CY8C4024LQ ARM Microcontroller
    • HC595 bit-shifter
    • 74HC4051D 8-channel analog multiplexer/demultiplexer
    • 74HC165D 8-bit parallel-in/serial out shift register
    • 74HC238D - 3-to-8 line decoder/demultiplexermxic
    • STM32F401RB - STMicroelectronics STM32F401RB - High-performance access line, Arm Cortex-M4 core with DSP and FPU, 128 Kbytes of Flash memory, 84 MHz CPU, ART Accelerator. Yes, apperently it accelerates art :)
    • MXIC MX25L8006E - 3V, 8M-bit[x 1/x 2] CMOS Serial flash memory
  6. Novation Launchkey mini Mk3 / FLkey mini Disassembly, The mastermind: step 6, image 1 of 3 Novation Launchkey mini Mk3 / FLkey mini Disassembly, The mastermind: step 6, image 2 of 3 Novation Launchkey mini Mk3 / FLkey mini Disassembly, The mastermind: step 6, image 3 of 3
    • Unscrew the four screw
    • Undo the ribon cable by pulling the black clamp ever so carefull.
    • Remove CPU board.
  7. Novation Launchkey mini Mk3 / FLkey mini Disassembly, The pitcher: step 7, image 1 of 1
    • Undo the ribbon cable.
    • Unscrew 4 screws.
    • Remove the board.
  8. Novation Launchkey mini Mk3 / FLkey mini Disassembly, The big boy: step 8, image 1 of 3 Novation Launchkey mini Mk3 / FLkey mini Disassembly, The big boy: step 8, image 2 of 3 Novation Launchkey mini Mk3 / FLkey mini Disassembly, The big boy: step 8, image 3 of 3
    • Unscrew 15 screws.
    • Remove the 8 rotary knob caps from the from of the board, by simply pulling on them. The main board can now be removed.
    • Removing the silicon pads as last, the midi keyboard is now fully disassembled.
I applaud Novation for making a device that is easy to open. No hidden screws and many screw indicators make this easily to repair. Just be careful with the ribbon cables.
What I don't understand is that I had to buy a complete new Novation FLKey to get features that work better with FL Studio. But looking inside, there seems to be no difference in hardware. So why not simply release a FL Studio driver? Maybe the firmware can be snarfed...
5 other people completed this guide.
TheDude
405 Reputation
2 Guides authored
0 Comments
Past 24 Hours: 4
Past 7 Days: 26
Past 30 Days: 111
All Time: 1,746
