NuVision 10.1 Atom Battery Replacement
  1. NuVision 10.1 Atom Battery Replacement, Camera: step 1, image 1 of 3 NuVision 10.1 Atom Battery Replacement, Camera: step 1, image 2 of 3 NuVision 10.1 Atom Battery Replacement, Camera: step 1, image 3 of 3
    • Turn the device screen side down.
    • Carefully remove the back piece with the iFixit opening tool.
  2. NuVision 10.1 Atom Battery Replacement: step 2, image 1 of 1
    • Remove the yellow tape covering the motherboard gently with your fingers.
  3. NuVision 10.1 Atom Battery Replacement: step 3, image 1 of 3 NuVision 10.1 Atom Battery Replacement: step 3, image 2 of 3 NuVision 10.1 Atom Battery Replacement: step 3, image 3 of 3
    • Pull the camera plug upward and away from the motherboard with your fingers.
    • Gently pull the camera from the device. The camera is held by tension.
  4. NuVision 10.1 Atom Battery Replacement, Speaker: step 4, image 1 of 1
    • Carefully remove silver tape with your fingers.
  5. NuVision 10.1 Atom Battery Replacement: step 5, image 1 of 2 NuVision 10.1 Atom Battery Replacement: step 5, image 2 of 2
    • Remove speakers gently using your fingers, they pop out easily.
    • Disconnect cords attached to the speaker from white pod.
  6. NuVision 10.1 Atom Battery Replacement, Motherboard: step 6, image 1 of 1
    • Disconnect the press-fit black and red curly wire from where it connects on the motherboard.
  7. NuVision 10.1 Atom Battery Replacement: step 7, image 1 of 3 NuVision 10.1 Atom Battery Replacement: step 7, image 2 of 3 NuVision 10.1 Atom Battery Replacement: step 7, image 3 of 3
    • Gently remove the battery's three ZIF connectors from the motherboard. Use your fingers.
    • Be careful not to puncture the battery.
  8. NuVision 10.1 Atom Battery Replacement: step 8, image 1 of 2 NuVision 10.1 Atom Battery Replacement: step 8, image 2 of 2
    • Disconnect the battery's bundled cable connector from the motherboard with fingers.
  9. NuVision 10.1 Atom Battery Replacement: step 9, image 1 of 3 NuVision 10.1 Atom Battery Replacement: step 9, image 2 of 3 NuVision 10.1 Atom Battery Replacement: step 9, image 3 of 3
    • Remove the four black 3.32mm screws on the corners of the motherboard using the Phillips #000 screwdriver. The motherboard should come out easily.
  10. NuVision 10.1 Atom Battery Replacement, Battery: step 10, image 1 of 3 NuVision 10.1 Atom Battery Replacement, Battery: step 10, image 2 of 3 NuVision 10.1 Atom Battery Replacement, Battery: step 10, image 3 of 3
    • Pry the battery away from the display screen gently using a nylon spudger or the plastic opening tools.
    • Using a metal spudger may bend or puncture the battery. Lithium batteries are prone to explode.
    • There is a lot of adhesive, take your time and be careful.
Carly Daniele
567 Reputation
5 Guides authored
USF Tampa, Team S1-G5, Leahy Spring 2019 Member of USF Tampa, Team S1-G5, Leahy Spring 2019
USFT-LEAHY-S19S1G5
5 Members
6 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 17
All Time: 894
