NuVision TM800A510L Battery Replacement
  1. NuVision TM800A510L Battery Replacement, Battery: step 1, image 1 of 2 NuVision TM800A510L Battery Replacement, Battery: step 1, image 2 of 2
    • Use a Heat Gun to loosen the adhesive under the backing of the device.
    • Use prying tools to lift up the back of the device to get underneath.
    • I recommend concentrating on one side of the device at a time and making sure the device is 'almost too hot to touch' before you begin using the prying tools.
    • You can use either metal or plastic prying tools. Keep in mind, though, that metal ones may scratch the device.
  2. NuVision TM800A510L Battery Replacement: step 2, image 1 of 2 NuVision TM800A510L Battery Replacement: step 2, image 2 of 2
    • Unlock all of the ribbons that cross or interfere with the battery.
    • Remove the unlocked ribbons if you can- this will make it easier to work with the battery later.
  3. NuVision TM800A510L Battery Replacement: step 3, image 1 of 1
    • Use plastic prying tools to peel up the battery. Metal prying tools may puncture the battery and cause more damage. If you MUST use metal prying tools, go slow.
    • This process may take some time since the battery is held down with adhesive.
    • It is not really recommended to use the Heat Gun on the battery. However, the heat will loosen the adhesive. Therefore, if you decide to use a Heat Gun, apply the heat to the battery from underneath the device (heat the screen).
  4. NuVision TM800A510L Battery Replacement: step 4, image 1 of 1
    • Desolder battery and wires from Motherboard HERE!
    • Once the wires are free, so is the battery. You should be able to replace the battery and its wires in full (as a package deal).
0 Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 20
All Time: 831
