Numark TT1600 Audio Jacks Replacement
  1. Numark TT1600 Audio Jacks Replacement, Audio Jacks: step 1, image 1 of 1
    • Flip over the turntable and remove the nine screws on the outer edges.
  2. Numark TT1600 Audio Jacks Replacement: step 2, image 1 of 2 Numark TT1600 Audio Jacks Replacement: step 2, image 2 of 2
    • Find the audio jacks located on the back side of the turntable.
    • Remove the screw located in between the right and left audio jacks.
  3. Numark TT1600 Audio Jacks Replacement: step 3, image 1 of 1
    • Remove the back cover by pulling it apart.
  4. Numark TT1600 Audio Jacks Replacement: step 4, image 1 of 1
    • Remove the grounding hardware located next to the audio jacks.
  5. Numark TT1600 Audio Jacks Replacement: step 5, image 1 of 2 Numark TT1600 Audio Jacks Replacement: step 5, image 2 of 2
    • Remove the ground screw and washers.
  6. Numark TT1600 Audio Jacks Replacement: step 6, image 1 of 1
    • Remove the remaining nut and washer.
  7. Numark TT1600 Audio Jacks Replacement: step 7, image 1 of 1
    • Remove the screw located on the back panel of the audio jack housing.
  8. Numark TT1600 Audio Jacks Replacement: step 8, image 1 of 3 Numark TT1600 Audio Jacks Replacement: step 8, image 2 of 3 Numark TT1600 Audio Jacks Replacement: step 8, image 3 of 3
    • Remove the screw that connects the audio jacks to the biggest circuit board via wire.
  9. Numark TT1600 Audio Jacks Replacement: step 9, image 1 of 1
    • Gently pull out the audio input jacks from the audio input housing.
Nikolai
254 Reputation
5 Guides authored
Cal Poly, Team 17-14, Regan Fall 2011 Member of Cal Poly, Team 17-14, Regan Fall 2011
CPSU-REGAN-F11S17G14
4 Members
11 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 9
All Time: 1,404
