Numark TT1600 Tone Arm Replacement
  1. Numark TT1600 Tone Arm Replacement, Tone Arm: step 1, image 1 of 2 Numark TT1600 Tone Arm Replacement, Tone Arm: step 1, image 2 of 2
    • Flip over the turntable and remove the 9 screws on the outer edges.
  2. Numark TT1600 Tone Arm Replacement: step 2, image 1 of 1
    • Remove the back cover by pulling it apart.
  3. Numark TT1600 Tone Arm Replacement: step 3, image 1 of 3 Numark TT1600 Tone Arm Replacement: step 3, image 2 of 3 Numark TT1600 Tone Arm Replacement: step 3, image 3 of 3
    • Remove the clip located on the backside of the audio jack housing by gently pulling it out.
    • There will be some resistance but continue to pull gently.
    • The clip is located right underneath the audio jacks.
  4. Numark TT1600 Tone Arm Replacement: step 4, image 1 of 3 Numark TT1600 Tone Arm Replacement: step 4, image 2 of 3 Numark TT1600 Tone Arm Replacement: step 4, image 3 of 3
    • Remove the screw that connects the black wire of the tone arm to the base of the audio jack housing.
  5. Numark TT1600 Tone Arm Replacement: step 5, image 1 of 2 Numark TT1600 Tone Arm Replacement: step 5, image 2 of 2
    • Gently pull the wire that you just unscrewed to release it from the clip.
  6. Numark TT1600 Tone Arm Replacement: step 6, image 1 of 3 Numark TT1600 Tone Arm Replacement: step 6, image 2 of 3 Numark TT1600 Tone Arm Replacement: step 6, image 3 of 3
    • Remove the two screws connecting the circuit board to the tone arm.
  7. Numark TT1600 Tone Arm Replacement: step 7, image 1 of 2 Numark TT1600 Tone Arm Replacement: step 7, image 2 of 2
    • Remove the two remaining screws connecting the tone arm to the device.
  8. Numark TT1600 Tone Arm Replacement: step 8, image 1 of 1
    • Flip the turntable back over to the top side.
    • Remove the counter weight located at the back of the tone arm.
  9. Numark TT1600 Tone Arm Replacement: step 9, image 1 of 3 Numark TT1600 Tone Arm Replacement: step 9, image 2 of 3 Numark TT1600 Tone Arm Replacement: step 9, image 3 of 3
    • Push out the pin keeping the tone arm in place using a Phillips #00 screwdriver.
    • Once you have pushed the pin out with the screwdriver, pull the rest of it out using your hand.
  10. Numark TT1600 Tone Arm Replacement: step 10, image 1 of 3 Numark TT1600 Tone Arm Replacement: step 10, image 2 of 3 Numark TT1600 Tone Arm Replacement: step 10, image 3 of 3
    • Pick up the tone arm and point the back end of it towards its base.
    • Push the back end of the tone arm into the hole.
    • Flip the turntable over and pull the tone arm all the way through the hole.
3 other people completed this guide.
Nikolai
254 Reputation
5 Guides authored
Cal Poly, Team 17-14, Regan Fall 2011 Member of Cal Poly, Team 17-14, Regan Fall 2011
CPSU-REGAN-F11S17G14
4 Members
11 Guides authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 7
Past 30 Days: 41
All Time: 8,290
