Nuphy Air75 Keyboard Switch Replacement
  1. Nuphy Air75 Keyboard Switch Replacement, Keyboard Switch: step 1, image 1 of 2 Nuphy Air75 Keyboard Switch Replacement, Keyboard Switch: step 1, image 2 of 2
    • Place your keyboard on a clean, well-lit surface.
    • Slide the keyboard power switch to the "off" position.
  2. Nuphy Air75 Keyboard Switch Replacement: step 2, image 1 of 3 Nuphy Air75 Keyboard Switch Replacement: step 2, image 2 of 3 Nuphy Air75 Keyboard Switch Replacement: step 2, image 3 of 3
    • Find the wire side of the keycap puller. Slide each wire around opposite sides of the key you are replacing.
    • Pull gently until the key cap comes off.
    • Pull the keycap straight up. This will prevent damage to adjacent keycaps.
  3. Nuphy Air75 Keyboard Switch Replacement: step 3, image 1 of 3 Nuphy Air75 Keyboard Switch Replacement: step 3, image 2 of 3 Nuphy Air75 Keyboard Switch Replacement: step 3, image 3 of 3
    • Use the other side of the switch puller, with two large metal prongs. Fit the prongs onto either side of the switch.
    • Pull the switch out using a side-to-side motion. When one side of the switch lifts up with an audible click, gently lift the other side to fully remove the switch.
    • Do not rock side-to-side into other keys. You can damage adjacent keycaps and the keyboard itself.
  4. Nuphy Air75 Keyboard Switch Replacement: step 4, image 1 of 2 Nuphy Air75 Keyboard Switch Replacement: step 4, image 2 of 2
    • Orient the replacement switch so that the colored, circular module is facing up.
    • Gently press down until you hear an audible click.
    • Place the keycap over the newly installed switch and gently press down.
  5. Nuphy Air75 Keyboard Switch Replacement: step 5, image 1 of 2 Nuphy Air75 Keyboard Switch Replacement: step 5, image 2 of 2
    • Turn the power switch to the "wired" or "wireless" position depending on your setup.
    • Test your keyboard and new key switch.
Finish Line
0 Guide Comments
Past 24 Hours: 8
Past 7 Days: 42
Past 30 Days: 188
All Time: 2,641
