Nvidia Shield Battery Assembly Replacement
  1. Nvidia Shield Battery Assembly Replacement, Remove Front Panel: step 1, image 1 of 3 Nvidia Shield Battery Assembly Replacement, Remove Front Panel: step 1, image 2 of 3 Nvidia Shield Battery Assembly Replacement, Remove Front Panel: step 1, image 3 of 3
    • Remove the seven 6.4mm T5 Torx screws from the back panel.
    • Use the spudger to separate the front and back panels.
  2. Nvidia Shield Battery Assembly Replacement, Remove Green Grill: step 2, image 1 of 2 Nvidia Shield Battery Assembly Replacement, Remove Green Grill: step 2, image 2 of 2
    • The green grill is not screwed in so it can be pulled right out.
  3. Nvidia Shield Battery Assembly Replacement, Remove Battery Cables: step 3, image 1 of 3 Nvidia Shield Battery Assembly Replacement, Remove Battery Cables: step 3, image 2 of 3 Nvidia Shield Battery Assembly Replacement, Remove Battery Cables: step 3, image 3 of 3
    • Remove the six 6.5mm T5 Torx screws.
    • Disconnect the power wires.
    • Peel back the copper tape and disconnect the black and white wires.
  4. Nvidia Shield Battery Assembly Replacement, Remove Battery Apparatus: step 4, image 1 of 1
    • Pull the battery apparatus out once all cables are removed.
5 other people completed this guide.
Andrew Barbanera
376 Reputation
2 Guides authored
USF Tampa, Team 1-1, Hickman Fall 2014 Member of USF Tampa, Team 1-1, Hickman Fall 2014
USFT-HICKMAN-F14S1G1
4 Members
18 Guides authored
5 Guide Comments
For replacement batteries, are they 18650? Do I want flat top or button tops?
evan - Reply
Hello,
any idea what connector the battery uses? I have a replacement pack but they put the cable on the wrong side of the pack (doesn’t fit backwards either)
Brett - Reply
The original cells are rated for 3.7v, 2450mAh, and I don't know how many amps but it's probably not that many. The form factor is flat-top 18650. I successfully did this repair using 3 Samsung 35E cells: https://www.18650batterystore.com/produc...
Charles Hall - Reply
hi! how is this holding up nowadays? i found my old nvidia shield in storage recently and the batteries are completely dead ;;
Canvas -
So, is this battery pack compatible? I read it has the connector in the wrong side
andres.430 - Reply
Past 24 Hours: 2
Past 7 Days: 12
Past 30 Days: 47
All Time: 7,079
