Nvidia Shield Battery Assembly Replacement
  1. Nvidia Shield Battery Assembly Replacement, Remove Front Panel: step 1, image 1 of 3 Nvidia Shield Battery Assembly Replacement, Remove Front Panel: step 1, image 2 of 3 Nvidia Shield Battery Assembly Replacement, Remove Front Panel: step 1, image 3 of 3
    • Remove the seven 6.4mm T5 Torx screws from the back panel.
    • Use the spudger to separate the front and back panels.
    For the rubber screw covers, it is easiest to push at them at the top, otherwise you have the possibility of damaging the surrounding rubber.
    Any hints at getting the center plastic screw cover out?
    Miles Raymond - Reply
  2. Nvidia Shield Battery Assembly Replacement, Remove Green Grill: step 2, image 1 of 2 Nvidia Shield Battery Assembly Replacement, Remove Green Grill: step 2, image 2 of 2
    • The green grill is not screwed in so it can be pulled right out.
  3. Nvidia Shield Battery Assembly Replacement, Remove Battery Cables: step 3, image 1 of 3 Nvidia Shield Battery Assembly Replacement, Remove Battery Cables: step 3, image 2 of 3 Nvidia Shield Battery Assembly Replacement, Remove Battery Cables: step 3, image 3 of 3
    • Remove the six 6.5mm T5 Torx screws.
    • Disconnect the power wires.
    • Peel back the copper tape and disconnect the black and white wires.
  4. Nvidia Shield Battery Assembly Replacement, Remove Battery Apparatus: step 4, image 1 of 1
    • Pull the battery apparatus out once all cables are removed.
5 other people completed this guide.
Andrew Barbanera
376 Reputation
2 Guides authored
USF Tampa, Team 1-1, Hickman Fall 2014 Member of USF Tampa, Team 1-1, Hickman Fall 2014
USFT-HICKMAN-F14S1G1
4 Members
18 Guides authored
4 Comments
For replacement batteries, are they 18650? Do I want flat top or button tops?
evan - Reply
Hello,
any idea what connector the battery uses? I have a replacement pack but they put the cable on the wrong side of the pack (doesn’t fit backwards either)
Brett - Reply
The original cells are rated for 3.7v, 2450mAh, and I don't know how many amps but it's probably not that many. The form factor is flat-top 18650. I successfully did this repair using 3 Samsung 35E cells: https://www.18650batterystore.com/produc...
Charles Hall - Reply
So, is this battery pack compatible? I read it has the connector in the wrong side
andres.430 - Reply
Past 24 Hours: 0
Past 7 Days: 10
Past 30 Days: 27
All Time: 6,516
