Nvidia Shield Controller Buttons Replacement
  1. Nvidia Shield Controller Buttons Replacement, Remove Front Panel: step 1, image 1 of 3 Nvidia Shield Controller Buttons Replacement, Remove Front Panel: step 1, image 2 of 3 Nvidia Shield Controller Buttons Replacement, Remove Front Panel: step 1, image 3 of 3
    • Remove the seven 6.4mm T5 Torx screws from the back panel.
    • Use the spudger to separate the front and back panels.
  2. Nvidia Shield Controller Buttons Replacement, Remove Green Grill: step 2, image 1 of 2 Nvidia Shield Controller Buttons Replacement, Remove Green Grill: step 2, image 2 of 2
    • The green grill is not screwed in so it can be pulled right out.
  3. Nvidia Shield Controller Buttons Replacement, Remove Battery Cables: step 3, image 1 of 3 Nvidia Shield Controller Buttons Replacement, Remove Battery Cables: step 3, image 2 of 3 Nvidia Shield Controller Buttons Replacement, Remove Battery Cables: step 3, image 3 of 3
    • Remove the six 6.5mm T5 Torx screws.
    • Disconnect the power wires.
    • Peel back the copper tape and disconnect the black and white wires.
  4. Nvidia Shield Controller Buttons Replacement, Remove Battery Apparatus: step 4, image 1 of 1
    • Pull the battery apparatus out once all cables are removed.
  5. Nvidia Shield Controller Buttons Replacement, Removing Button Board: step 5, image 1 of 3 Nvidia Shield Controller Buttons Replacement, Removing Button Board: step 5, image 2 of 3 Nvidia Shield Controller Buttons Replacement, Removing Button Board: step 5, image 3 of 3
    • Remove seven 6.5 mm T5 torx screws from the button board.
    • Refer to the second image as some screws are not visible in the first image. One of these screws is covered by the orange ribbon.
    • Remove the button board.
7 other people completed this guide.
Daniel Eberhart
379 Reputation
1 Guide authored
USF Tampa, Team 1-1, Hickman Fall 2014 Member of USF Tampa, Team 1-1, Hickman Fall 2014
USFT-HICKMAN-F14S1G1
4 Members
18 Guides authored
2 Comments
From where can I get the buttons?
Chirag Khatri - Reply
Hey:) I am not sure
Knut Gunnar Walle - Reply
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 4
All Time: 6,176
