Nvidia Shield Controller Motherboard Replacement
  1. Nvidia Shield Controller Motherboard Replacement, Motherboard: step 1, image 1 of 3 Nvidia Shield Controller Motherboard Replacement, Motherboard: step 1, image 2 of 3 Nvidia Shield Controller Motherboard Replacement, Motherboard: step 1, image 3 of 3
    • Use a Torx TR6 screwdriver to remove the six 7mm screws from the back of the controller.
  2. Nvidia Shield Controller Motherboard Replacement: step 2, image 1 of 2 Nvidia Shield Controller Motherboard Replacement: step 2, image 2 of 2
    • Use a plastic opening tool to pry open the back frame of the controller.
  3. Nvidia Shield Controller Motherboard Replacement: step 3, image 1 of 3 Nvidia Shield Controller Motherboard Replacement: step 3, image 2 of 3 Nvidia Shield Controller Motherboard Replacement: step 3, image 3 of 3
    • Use the Torx TR6 bit to remove the two 7mm screws behind the analog sticks.
    • Unplug the power supply cable from the analog stick assembly.
  4. Nvidia Shield Controller Motherboard Replacement: step 4, image 1 of 3 Nvidia Shield Controller Motherboard Replacement: step 4, image 2 of 3 Nvidia Shield Controller Motherboard Replacement: step 4, image 3 of 3
    Tool used on this step:
    Buy
    • Use a pair of tweezers to unplug the rumble motors from the motherboard.
    • Use a pair of tweezers to unplug the battery cable from the motherboard.
  5. Nvidia Shield Controller Motherboard Replacement: step 5, image 1 of 3 Nvidia Shield Controller Motherboard Replacement: step 5, image 2 of 3 Nvidia Shield Controller Motherboard Replacement: step 5, image 3 of 3
    • Use a Torx TR6 screwdriver to remove the two 7mm screws towards the top of the frame.
    • Use the Torx T5 screwdriver to remove the two 5mm screws in the bottom corners of the frame.
    • Lift out the motherboard from the case.
3 other people completed this guide.
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 28
All Time: 2,767
