Nvidia Shield Fan Replacement
  1. Nvidia Shield Fan Replacement, Remove Front Panel: step 1, image 1 of 3 Nvidia Shield Fan Replacement, Remove Front Panel: step 1, image 2 of 3 Nvidia Shield Fan Replacement, Remove Front Panel: step 1, image 3 of 3
    • Remove the seven 6.4mm T5 Torx screws from the back panel.
    • Use the spudger to separate the front and back panels.
  2. Nvidia Shield Fan Replacement, Remove Green Grill: step 2, image 1 of 2 Nvidia Shield Fan Replacement, Remove Green Grill: step 2, image 2 of 2
    • The green grill is not screwed in so it can be pulled right out.
  3. Nvidia Shield Fan Replacement, Remove Battery Cables: step 3, image 1 of 3 Nvidia Shield Fan Replacement, Remove Battery Cables: step 3, image 2 of 3 Nvidia Shield Fan Replacement, Remove Battery Cables: step 3, image 3 of 3
    • Remove the six 6.5mm T5 Torx screws.
    • Disconnect the power wires.
    • Peel back the copper tape and disconnect the black and white wires.
  4. Nvidia Shield Fan Replacement, Remove Battery Apparatus: step 4, image 1 of 1
    • Pull the battery apparatus out once all cables are removed.
  5. Nvidia Shield Fan Replacement, Removing Fan: step 5, image 1 of 3 Nvidia Shield Fan Replacement, Removing Fan: step 5, image 2 of 3 Nvidia Shield Fan Replacement, Removing Fan: step 5, image 3 of 3
    • Cooling is important for electronics, the last thing they want is to overheat.
    • Remove the two 7.3mm and four 8.4mm T5 Torx screws and disconnect the power cable.
    • Lift the fan free after the screws and cable are removed.
4 other people completed this guide.
Marc Perez
545 Reputation
2 Guides authored
USF Tampa, Team 1-1, Hickman Fall 2014 Member of USF Tampa, Team 1-1, Hickman Fall 2014
USFT-HICKMAN-F14S1G1
4 Members
18 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 15
All Time: 3,139
