Nvidia Shield Pro Android TV Controller D-Pad Replacement
  1. Nvidia Shield Pro Android TV Controller D-Pad Replacement, Bluetooth Controller D-Pad: step 1, image 1 of 3 Nvidia Shield Pro Android TV Controller D-Pad Replacement, Bluetooth Controller D-Pad: step 1, image 2 of 3 Nvidia Shield Pro Android TV Controller D-Pad Replacement, Bluetooth Controller D-Pad: step 1, image 3 of 3
    • Remove the six T6 Torx screws from the back of the controller.
  2. Nvidia Shield Pro Android TV Controller D-Pad Replacement: step 2, image 1 of 1
    • Gently open the top frame of the cover with the plastic opening tool.
  3. Nvidia Shield Pro Android TV Controller D-Pad Replacement: step 3, image 1 of 2 Nvidia Shield Pro Android TV Controller D-Pad Replacement: step 3, image 2 of 2
    • Gently pull the wire connector out of its socket, separating the two halves of the controller.
  4. Nvidia Shield Pro Android TV Controller D-Pad Replacement: step 4, image 1 of 1
    • Remove the wire attached to the circular piece.
  5. Nvidia Shield Pro Android TV Controller D-Pad Replacement: step 5, image 1 of 2 Nvidia Shield Pro Android TV Controller D-Pad Replacement: step 5, image 2 of 2
    • Carefully remove the two T6 Torx screws from either side of the motherboard.
  6. Nvidia Shield Pro Android TV Controller D-Pad Replacement: step 6, image 1 of 1
    • Remove the yellow plug from its socket.
  7. Nvidia Shield Pro Android TV Controller D-Pad Replacement: step 7, image 1 of 2 Nvidia Shield Pro Android TV Controller D-Pad Replacement: step 7, image 2 of 2
    • Remove the two T6 Torx screws.
  8. Nvidia Shield Pro Android TV Controller D-Pad Replacement: step 8, image 1 of 1
    • Slowly pull up the primary circuit board of the controller until the D-pad is revealed.
    • Carefully remove the board.
  9. Nvidia Shield Pro Android TV Controller D-Pad Replacement: step 9, image 1 of 1
    • Gently remove and replace the D-Pad.
Ben Carrasco
347 Reputation
2 Guides authored
Cal Poly, Team S18-G2, White Winter 2020 Member of Cal Poly, Team S18-G2, White Winter 2020
CPSU-WHITE-W20S18G2
4 Members
14 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 8
Past 30 Days: 42
All Time: 1,988
