Nvidia Shield Pro Android TV Controller Rumble Motor Replacement
  1. Nvidia Shield Pro Android TV Controller Rumble Motor Replacement, Thumbsticks: step 1, image 1 of 3 Nvidia Shield Pro Android TV Controller Rumble Motor Replacement, Thumbsticks: step 1, image 2 of 3 Nvidia Shield Pro Android TV Controller Rumble Motor Replacement, Thumbsticks: step 1, image 3 of 3
    • Remove the six T6 Torx screws from the back of the controller.
  2. Nvidia Shield Pro Android TV Controller Rumble Motor Replacement: step 2, image 1 of 1
    • Gently pry open the top frame of the cover with a plastic opening tool.
  3. Nvidia Shield Pro Android TV Controller Rumble Motor Replacement: step 3, image 1 of 2 Nvidia Shield Pro Android TV Controller Rumble Motor Replacement: step 3, image 2 of 2
    • Gently pull the wire connector directly out of its socket, separating the two halves of the controller.
  4. Nvidia Shield Pro Android TV Controller Rumble Motor Replacement: step 4, image 1 of 2 Nvidia Shield Pro Android TV Controller Rumble Motor Replacement: step 4, image 2 of 2
    • Remove the two T6 Torx screws.
  5. Nvidia Shield Pro Android TV Controller Rumble Motor Replacement: step 5, image 1 of 2 Nvidia Shield Pro Android TV Controller Rumble Motor Replacement: step 5, image 2 of 2
    • Remove the guard piece that secures the thumb-sticks to the controller.
    • Apply vertical pressure with two fingers to carefully pop off the thumb-stick(s) in need of repair.
    • Replace it by sliding a new thumb-stick onto the plastic post that secured the old one.
  6. Nvidia Shield Pro Android TV Controller Rumble Motor Replacement, Rumble Motors: step 6, image 1 of 3 Nvidia Shield Pro Android TV Controller Rumble Motor Replacement, Rumble Motors: step 6, image 2 of 3 Nvidia Shield Pro Android TV Controller Rumble Motor Replacement, Rumble Motors: step 6, image 3 of 3
    • Grip the plugs as close to their ports as possible and pull them directly up and out.
    • Lift the rumble motors up and out of the chassis.
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 5
All Time: 273
