Nvidia Shield Pro Android TV Controller Triggers Replacement
  1. Nvidia Shield Pro Android TV Controller Triggers Replacement, Bluetooth Controller Thumbsticks: step 1, image 1 of 3 Nvidia Shield Pro Android TV Controller Triggers Replacement, Bluetooth Controller Thumbsticks: step 1, image 2 of 3 Nvidia Shield Pro Android TV Controller Triggers Replacement, Bluetooth Controller Thumbsticks: step 1, image 3 of 3
    • Remove the six T6 Torx screws from the back of the controller.
  2. Nvidia Shield Pro Android TV Controller Triggers Replacement: step 2, image 1 of 1
    • Gently pry open the top frame of the cover with a plastic opening tool.
  3. Nvidia Shield Pro Android TV Controller Triggers Replacement: step 3, image 1 of 2 Nvidia Shield Pro Android TV Controller Triggers Replacement: step 3, image 2 of 2
    • Gently pull the wire connector directly out of its socket, separating the two halves of the controller.
  4. Nvidia Shield Pro Android TV Controller Triggers Replacement: step 4, image 1 of 2 Nvidia Shield Pro Android TV Controller Triggers Replacement: step 4, image 2 of 2
    • Remove the two T6 Torx screws.
  5. Nvidia Shield Pro Android TV Controller Triggers Replacement: step 5, image 1 of 2 Nvidia Shield Pro Android TV Controller Triggers Replacement: step 5, image 2 of 2
    • Remove the guard piece that secures the thumb-sticks to the controller.
    • Apply vertical pressure with two fingers to carefully pop off the thumb-stick(s) in need of repair.
    • Replace it by sliding a new thumb-stick onto the plastic post that secured the old one.
  6. Nvidia Shield Pro Android TV Controller Triggers Replacement, Triggers: step 6, image 1 of 3 Nvidia Shield Pro Android TV Controller Triggers Replacement, Triggers: step 6, image 2 of 3 Nvidia Shield Pro Android TV Controller Triggers Replacement, Triggers: step 6, image 3 of 3
    • Use a Torx T6 screwdriver to remove the two 7 mm screws from the triggers (one on each trigger).
    • Use a Torx T5 screwdriver to remove the two 5 mm screws securing the motherboard.
    • Gently lift the motherboard from the controller housing.
  7. Nvidia Shield Pro Android TV Controller Triggers Replacement: step 7, image 1 of 3 Nvidia Shield Pro Android TV Controller Triggers Replacement: step 7, image 2 of 3 Nvidia Shield Pro Android TV Controller Triggers Replacement: step 7, image 3 of 3
    • Use a Torx T5 screwdriver to remove the two 5 mm screws from the motherboard.
    • Carefully pull the trigger directly out of its socket.
One Comment
how do you put the shoulder buttons back in. They fell out when I was trying to replace the battery
demarko9999 - Reply
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 7
All Time: 283
