Nvidia Shield TV 1st Generation Hard Drive Replacement
  1. Nvidia Shield TV 1st Generation Hard Drive Replacement, Hard Drive: step 1, image 1 of 1
    • Flip the device over and use a plastic opening tool to remove the bottom cover.
  2. Nvidia Shield TV 1st Generation Hard Drive Replacement: step 2, image 1 of 3 Nvidia Shield TV 1st Generation Hard Drive Replacement: step 2, image 2 of 3 Nvidia Shield TV 1st Generation Hard Drive Replacement: step 2, image 3 of 3
    • Remove the tape that is covering the hard drive.
    • Place tape aside in a safe place so it can be reused to secure the hard drive when reassembling.
  3. Nvidia Shield TV 1st Generation Hard Drive Replacement: step 3, image 1 of 1
    • Remove the indicated screw using the T6 Torx Screwdriver.
  4. Nvidia Shield TV 1st Generation Hard Drive Replacement: step 4, image 1 of 2 Nvidia Shield TV 1st Generation Hard Drive Replacement: step 4, image 2 of 2
    • Gently pull out the hard drive.
    • Remove the connector pins from the hard drive.
5 other people completed this guide.
Joshua Neally
581 Reputation
4 Guides authored
USF Tampa, Team S16-G6, Eyestone Fall 2017 Member of USF Tampa, Team S16-G6, Eyestone Fall 2017
USFT-EYESTONE-F17S16G6
3 Members
7 Guides authored
7 Comments
How can I get a replacement sata cable? My tore when trying to replace with ssd.
3_D - Reply
This guide completely skips over the details on how to disconnect the cables. This is by far the trickiest part of this operation. The fact that the commenter above tore his SATA cable is proof that crucial steps of this procedure are missing!
ctphillips - Reply
This Fails to Mention The lower end version of the Nvidia Shield Console(16GB Storage) Is missing the cable that goes to the HDD and even the and even the soldering mounts to put a HDD in a 16GB version.
-B
Rob Craig - Reply
The part that is connected to the Sata connector for the HD with the ribbon attached how do I get a replacement one please
Steve Roe - Reply
How on earth do you disconnect the flat SATA cable from the motherboard safely?
Tobias Biehl - Reply
Past 24 Hours: 1
Past 7 Days: 10
Past 30 Days: 69
All Time: 8,976
