Nvidia Shield Tablet Motherboard Replacement
  1. Nvidia Shield Tablet Motherboard Replacement, Rear Case: step 1, image 1 of 2 Nvidia Shield Tablet Motherboard Replacement, Rear Case: step 1, image 2 of 2
    • First, remove the stylus from your tablet.
  2. Nvidia Shield Tablet Motherboard Replacement: step 2, image 1 of 3 Nvidia Shield Tablet Motherboard Replacement: step 2, image 2 of 3 Nvidia Shield Tablet Motherboard Replacement: step 2, image 3 of 3
    Tool used on this step:
    Anti-Static Wrist Strap
    $7.95
    Buy
    • Set the tablet so the buttons, microSD, and stylus port are facing you.
    • Open the microSD slot.
    • Using the flat end of the spudger tool, carefully pry open the case starting from the microSD slot, slowly sliding the spudger along the inside edge of the case.
    • You may want to put on your anti-static wrist strap at this point as the motherboard will be vulnerable to physical touch and electrostatic shock after the casing is removed.
  3. Nvidia Shield Tablet Motherboard Replacement: step 3, image 1 of 2 Nvidia Shield Tablet Motherboard Replacement: step 3, image 2 of 2
    • As you remove your case, be aware of small clips along the edges.
    • Finally, set the old casing aside.
  4. Nvidia Shield Tablet Motherboard Replacement, Motherboard: step 4, image 1 of 1
    $7.95
    Buy
    • Carefully use the precision tweezers to unplug the ribbon cable.
    • Be sure to have your anti-static wrist strap on for this procedure.
  5. Nvidia Shield Tablet Motherboard Replacement: step 5, image 1 of 3 Nvidia Shield Tablet Motherboard Replacement: step 5, image 2 of 3 Nvidia Shield Tablet Motherboard Replacement: step 5, image 3 of 3
    • Remove the two 6.5 mm Phillips #00 screws and seven 3.0 mm Phillips #00 screws.
  6. Nvidia Shield Tablet Motherboard Replacement: step 6, image 1 of 3 Nvidia Shield Tablet Motherboard Replacement: step 6, image 2 of 3 Nvidia Shield Tablet Motherboard Replacement: step 6, image 3 of 3
    • Use a pair of tweezers to disconnect the three black antenna cables from the motherboard.
    • Use the flat end of the spudger tool to carefully pry up the motherboard.
    • In the first Shield, the stylus ribbon cable is located under the right side of board. While there are 2 additional cables for the cameras underneath the left end of the board. Be sure to loosen the cameras before lifting the board.
  7. Nvidia Shield Tablet Motherboard Replacement: step 7, image 1 of 2 Nvidia Shield Tablet Motherboard Replacement: step 7, image 2 of 2
    • Desolder the positive and negative battery cables from the motherboard.
    • Make sure to note which wire goes where, you don't want to re-solder the wires backwards!
    • The motherboard should now come free.
6 other people completed this guide.
Molly Bauer
1,478 Reputation
6 Guides authored
USF Tampa, Team 2-2, Blackwell Fall 2015 Member of USF Tampa, Team 2-2, Blackwell Fall 2015
USFT-BLACKWELL-F15S2G2
3 Members
11 Guides authored
9 Guide Comments
Where do you obtain a new motherboard?
imprintcave - Reply
The real question is more about how to find a new shield tablet motherboard ??
willixlive - Reply
where can i buy the motherboard
Gurjot Dhaliwal - Reply
waar kan ik een nieuw shield moederbord kopen?
tom1vangestel - Reply
Hello, I'm looking for a description of the various ribbon connectors on the motherboard.
I'm also looking for a hint to solve a problem I have after replacing the screen+digitizer: the right side (half) of the touch screen does'n work.
Laurent Zanoni - Reply
Past 24 Hours: 2
Past 7 Days: 7
Past 30 Days: 30
All Time: 9,832
