Nvidia Shield Tablet Speaker Replacement
  1. Nvidia Shield Tablet Speaker Replacement, Rear Case: step 1, image 1 of 2 Nvidia Shield Tablet Speaker Replacement, Rear Case: step 1, image 2 of 2
    • First, remove the stylus from your tablet.
  2. Nvidia Shield Tablet Speaker Replacement: step 2, image 1 of 3 Nvidia Shield Tablet Speaker Replacement: step 2, image 2 of 3 Nvidia Shield Tablet Speaker Replacement: step 2, image 3 of 3
    Tool used on this step:
    Anti-Static Wrist Strap
    $7.95
    Buy
    • Set the tablet so the buttons, microSD, and stylus port are facing you.
    • Open the microSD slot.
    • Using the flat end of the spudger tool, carefully pry open the case starting from the microSD slot, slowly sliding the spudger along the inside edge of the case.
    • You may want to put on your anti-static wrist strap at this point as the motherboard will be vulnerable to physical touch and electrostatic shock after the casing is removed.
  3. Nvidia Shield Tablet Speaker Replacement: step 3, image 1 of 2 Nvidia Shield Tablet Speaker Replacement: step 3, image 2 of 2
    • As you remove your case, be aware of small clips along the edges.
    • Finally, set the old casing aside.
  4. Nvidia Shield Tablet Speaker Replacement, Speaker: step 4, image 1 of 1
    • Orient your tablet so that the top of the tablet is furthest away from you.
    • Locate the top speaker, a black semi-rectangular piece on the top right side of the tablet.
  5. Nvidia Shield Tablet Speaker Replacement: step 5, image 1 of 1
    • Remove the two 3.0 mm Phillips #00 screws securing the speaker.
  6. Nvidia Shield Tablet Speaker Replacement: step 6, image 1 of 3 Nvidia Shield Tablet Speaker Replacement: step 6, image 2 of 3 Nvidia Shield Tablet Speaker Replacement: step 6, image 3 of 3
    • Gently pry the speaker up with the flat end of a spudger.
    • Use a plastic opening tool to peel up the tape covering the speaker wire.
  7. Nvidia Shield Tablet Speaker Replacement: step 7, image 1 of 2 Nvidia Shield Tablet Speaker Replacement: step 7, image 2 of 2
    $7.95
    Buy
    • Next, with a gentle but firm grip, pull the audio input ribbon with the precision tweezers.
    • Finally, unplug the power source from your speaker using the precision tweezers.
    • Make sure you are using your anti-static wrist strap.
Molly Bauer
1,478 Reputation
6 Guides authored
USF Tampa, Team 2-2, Blackwell Fall 2015 Member of USF Tampa, Team 2-2, Blackwell Fall 2015
USFT-BLACKWELL-F15S2G2
3 Members
11 Guides authored
1 Guide Comment
This didn't work
Riley Schork - Reply
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 21
All Time: 2,814
