ORFELD EV-660-S222 Power Button Spring Replacement
  1. ORFELD EV-660-S222 Power Button Spring Replacement, Power Button Spring: step 1, image 1 of 1
    • Separate the dust cover and the motor from the vacuum body by pressing the eject button.
  2. ORFELD EV-660-S222 Power Button Spring Replacement: step 2, image 1 of 2 ORFELD EV-660-S222 Power Button Spring Replacement: step 2, image 2 of 2
    • Place the vacuum on its side, with the screws facing towards you.
    • Remove the 11.5 mm screws using a Phillips #1 screwdriver.
  3. ORFELD EV-660-S222 Power Button Spring Replacement: step 3, image 1 of 2 ORFELD EV-660-S222 Power Button Spring Replacement: step 3, image 2 of 2
    Tool used on this step:
    Buy
    • Using tweezers, remove the sticker connecting the two halves.
    • Use the opening pick to gently separate the top half and the bottom half of the vacuum.
    • Press the blue buttons near the sides of the battery LEDs to remove the top half.
  4. ORFELD EV-660-S222 Power Button Spring Replacement: step 4, image 1 of 1
    • Lift the battery slightly to reveal the pin connectors.
    • Gently disconnect the six-pin connector from the battery.
  5. ORFELD EV-660-S222 Power Button Spring Replacement: step 5, image 1 of 3 ORFELD EV-660-S222 Power Button Spring Replacement: step 5, image 2 of 3 ORFELD EV-660-S222 Power Button Spring Replacement: step 5, image 3 of 3
    • Gently pull out the power button from the board.
    • Gently pull up and twist the old spring off of the button.
0 Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 6
All Time: 69
