Oculus Rift CV1 Facial Interface Replacement
  1. Oculus Rift CV1 Facial Interface Replacement, Facial Interface: step 1, image 1 of 1
    • Pull firmly from the top of the headset facial interface to remove the foam frame.
  2. Oculus Rift CV1 Facial Interface Replacement: step 2, image 1 of 1
    • Remove the six T3 4mm screws from the top and bottom edges of the case.
  3. Oculus Rift CV1 Facial Interface Replacement: step 3, image 1 of 1
    • Insert the spudger underneath the edge of the lens on the left or right side.
    • Slide the spudger upwards and around the edge of the frame to undo the tabs underneath.
    • Repeat for the other side of the frame.
  4. Oculus Rift CV1 Facial Interface Replacement: step 4, image 1 of 3 Oculus Rift CV1 Facial Interface Replacement: step 4, image 2 of 3 Oculus Rift CV1 Facial Interface Replacement: step 4, image 3 of 3
    • Lift up the frame to see a tab hidden underneath the lycra mesh along the edge of the lens.
    • Pull up on the tab with the spudger.
    • Repeat for the corresponding tab on the other lens.
  5. Oculus Rift CV1 Facial Interface Replacement: step 5, image 1 of 1
    • Lift up on the plastic frame around the lens.
    • Slide a finger around the inside edge, pulling outward from the center of the lens to release the other tabs.
    • Repeat for the frame on the other lens.
  6. Oculus Rift CV1 Facial Interface Replacement: step 6, image 1 of 1
    • Pull up along the outer frame.
    • Remove the facial interface.
Kyle Anderson
226 Reputation
1 Guide authored
Cal Poly, Team S18-G4, White Winter 2019 Member of Cal Poly, Team S18-G4, White Winter 2019
CPSU-WHITE-W19S18G4
3 Members
10 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 8
Past 30 Days: 50
All Time: 5,596
