Oculus Rift Control Box Motherboard Replacement
  1. Oculus Rift Control Box Motherboard Replacement, Control Box Bottom Cover: step 1, image 1 of 3 Oculus Rift Control Box Motherboard Replacement, Control Box Bottom Cover: step 1, image 2 of 3 Oculus Rift Control Box Motherboard Replacement, Control Box Bottom Cover: step 1, image 3 of 3
    • Use a plastic opening tool to carefully pry off the four rubber feet from the control box.
    • You have now revealed the four 9 mm Phillips #1 screws underneath the rubber feet.
  2. Oculus Rift Control Box Motherboard Replacement: step 2, image 1 of 3 Oculus Rift Control Box Motherboard Replacement: step 2, image 2 of 3 Oculus Rift Control Box Motherboard Replacement: step 2, image 3 of 3
    • Use a Phillips #1 Screwdriver to unscrew the four 9mm Phillips screws on the bottom of the control box.
    • You can now remove the bottom lid of the control box. It should come apart easily.
  3. Oculus Rift Control Box Motherboard Replacement, Control Box  Motherboard: step 3, image 1 of 3 Oculus Rift Control Box Motherboard Replacement, Control Box  Motherboard: step 3, image 2 of 3 Oculus Rift Control Box Motherboard Replacement, Control Box  Motherboard: step 3, image 3 of 3
    • Use your finger(s) to start lifting the motherboard from the control box casing. While doing so, use your other hand to push the DVI connector into the control box casing.
    • When the DVI connector has cleared the casing, lift the motherboard.
    • Be careful! There should be two sets of wires still connected to the control box - do not tug on them. Simply flip the motherboard over to access these wires.
    • When reassembling the device, ensure that all of the wires are clear of the buttons.
  4. Oculus Rift Control Box Motherboard Replacement: step 4, image 1 of 3 Oculus Rift Control Box Motherboard Replacement: step 4, image 2 of 3 Oculus Rift Control Box Motherboard Replacement: step 4, image 3 of 3
    • Use a plastic opening tool or your fingernails to disconnect the grey wire connectors. To make removal easier, pry the left and right edges to carefully remove the connector.
    • Do so for both of the wires attached to the motherboard.
    • Now fully separate the motherboard from the control box casing.
Audrey Chan
201 Reputation
2 Guides authored
Cal Poly, Team 70-5, Forte Winter 2015 Member of Cal Poly, Team 70-5, Forte Winter 2015
CPSU-FORTE-W15S70G5
4 Members
6 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 5
Past 30 Days: 15
All Time: 1,243
