Oculus Rift Development Kit 2 Headset Motherboard Replacement
  1. Oculus Rift Development Kit 2 Headset Motherboard Replacement, Eye Relief Adjustment Screw: step 1, image 1 of 3 Oculus Rift Development Kit 2 Headset Motherboard Replacement, Eye Relief Adjustment Screw: step 1, image 2 of 3 Oculus Rift Development Kit 2 Headset Motherboard Replacement, Eye Relief Adjustment Screw: step 1, image 3 of 3
    • Remove front cover plate.
    • Unplug the USB and HDMI cables from the Oculus Rift DK2.
  2. Oculus Rift Development Kit 2 Headset Motherboard Replacement: step 2, image 1 of 3 Oculus Rift Development Kit 2 Headset Motherboard Replacement: step 2, image 2 of 3 Oculus Rift Development Kit 2 Headset Motherboard Replacement: step 2, image 3 of 3
    • Remove the four 3/8" Phillips #0 screws from the inner portion of the headset.
  3. Oculus Rift Development Kit 2 Headset Motherboard Replacement: step 3, image 1 of 2 Oculus Rift Development Kit 2 Headset Motherboard Replacement: step 3, image 2 of 2
    • With the screws removed, gently pull the headband frame apart from the headset.
  4. Oculus Rift Development Kit 2 Headset Motherboard Replacement, Remove Lens: step 4, image 1 of 2 Oculus Rift Development Kit 2 Headset Motherboard Replacement, Remove Lens: step 4, image 2 of 2
    • With the Oculus facing up, twist the right lens clockwise and lift it out. Repeat for the left lens twisting counterclockwise instead.
  5. Oculus Rift Development Kit 2 Headset Motherboard Replacement, Headset Motherboard: step 5, image 1 of 1
    Tool used on this step:
    Buy
    • Using tweezers, carefully lift the four rubber plugs as shown. They are a bit snug and you may need to jiggle them free with the tweezers.
  6. Oculus Rift Development Kit 2 Headset Motherboard Replacement: step 6, image 1 of 1
    • Remove the four 3/8" screws attaching the eyewear enclosure to the front casing.
    • Read the next step before removing the faceplate!
  7. Oculus Rift Development Kit 2 Headset Motherboard Replacement: step 7, image 1 of 2 Oculus Rift Development Kit 2 Headset Motherboard Replacement: step 7, image 2 of 2
    • Carefully separate the faceplate and the cover. Gently rest the cover plate on top of the faceplate as shown in the pictures.
    • Do not use excessive force when separating these two pieces. There is a delicate ribbon cable connected to each.
  8. Oculus Rift Development Kit 2 Headset Motherboard Replacement: step 8, image 1 of 2 Oculus Rift Development Kit 2 Headset Motherboard Replacement: step 8, image 2 of 2
    • Gently pull out the small side tabs on the ribbon cable connector as shown to release the cable.
    • Push the tabs away from you, with the headset oriented as pictured. Carefully slide the ribbon cable out.
    • The headset should now be two separate pieces.
  9. Oculus Rift Development Kit 2 Headset Motherboard Replacement: step 9, image 1 of 3 Oculus Rift Development Kit 2 Headset Motherboard Replacement: step 9, image 2 of 3 Oculus Rift Development Kit 2 Headset Motherboard Replacement: step 9, image 3 of 3
    • Unscrew the three 1/4" Phillips #00 screws as pictured and use the tweezers to lift them out.
  10. Oculus Rift Development Kit 2 Headset Motherboard Replacement: step 10, image 1 of 1
    • Lift the tape and gently pry up the video data ribbon cable using the plastic opening tool as shown.
  11. Oculus Rift Development Kit 2 Headset Motherboard Replacement: step 11, image 1 of 3 Oculus Rift Development Kit 2 Headset Motherboard Replacement: step 11, image 2 of 3 Oculus Rift Development Kit 2 Headset Motherboard Replacement: step 11, image 3 of 3
    • Gently pry back the motherboard clips to release the motherboard. The motherboard should now lift free.
7 other people completed this guide.
Adam
661 Reputation
4 Guides authored
Cal Poly, Team 18-5, Maness Winter 2015 Member of Cal Poly, Team 18-5, Maness Winter 2015
CPSU-MANESS-W15S18G5
4 Members
6 Guides authored
1 Guide Comment
hi.
you know where possible buy the new motherboard?
Szatmari Attila - Reply
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 9
All Time: 2,653
