Olympus 850SW Battery Replacement
  1. Olympus 850SW Battery Replacement, Battery: step 1, image 1 of 1
    • Locate the battery compartment on the bottom panel of the camera.
  2. Olympus 850SW Battery Replacement: step 2, image 1 of 2 Olympus 850SW Battery Replacement: step 2, image 2 of 2
    • Using a PH00 Phillips Screwdriver, unscrew the one screw located on the latch.
  3. Olympus 850SW Battery Replacement: step 3, image 1 of 3 Olympus 850SW Battery Replacement: step 3, image 2 of 3 Olympus 850SW Battery Replacement: step 3, image 3 of 3
    • Find the arrows on the compartment, remove the small black plastic piece, and release the latch.
  4. Olympus 850SW Battery Replacement: step 4, image 1 of 1
    • Allow the latch to completely open and insert the battery, with the writing side up.
    • The battery slot is the bigger slot. The smaller slot is for the memory card.
  5. Olympus 850SW Battery Replacement: step 5, image 1 of 1
    • Close the latch. You will hear a click when the compartment is fully closed.
  6. Olympus 850SW Battery Replacement: step 6, image 1 of 1
    • Place the small black piece back in its' place.
  7. Olympus 850SW Battery Replacement: step 7, image 1 of 1
    • Place the metal cover back over the closed latch, and screw the screw back in.
0 Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 17
All Time: 838
