Olympus C-765 LCD Screen Replacement
  1. Olympus C-765 LCD Screen Replacement, LCD Screen: step 1, image 1 of 3 Olympus C-765 LCD Screen Replacement, LCD Screen: step 1, image 2 of 3 Olympus C-765 LCD Screen Replacement, LCD Screen: step 1, image 3 of 3
    • Remove all the screws using your Phillips #00 holding the back plate in place. This includes:
    • On the Back: Unscrew the 4mm screw to the right of the viewfinder.
    • On the Bottom:
    • Unscrew the 3mm screw in the top left corner.
    • Unscrew the four 3mm screws under the battery cover.
    • On the Right Side: Unscrew the one 3mm screw holding the right-side panel.
    • On the Left Side: Unscrew the two 2mm screws holding the left-side panel.
  2. Olympus C-765 LCD Screen Replacement: step 2, image 1 of 2 Olympus C-765 LCD Screen Replacement: step 2, image 2 of 2
    • After you remove the back cover:
    • Gently pull the two ribbon cables out of their sockets.
    • Gently disconnect the white cable.
  3. Olympus C-765 LCD Screen Replacement: step 3, image 1 of 3 Olympus C-765 LCD Screen Replacement: step 3, image 2 of 3 Olympus C-765 LCD Screen Replacement: step 3, image 3 of 3
    • Peel the black tape off the back of the LCD.
    • Using the Phillips #00 remove the four 3mm screws on the LCD bracket.
    • Remove the two 2mm screws from the top of the bracket.
    • Use a spudger to pop the LCD screen out of the camera’s backplate.
    • When the bracket comes off, the buttons from the top section may fall out of place. If this happens then put them back in the position they were in.
2 other people completed this guide.
Mason Morgan
115 Reputation
6 Guides authored
Cal Poly, Team 12-33, Maness Spring 2011 Member of Cal Poly, Team 12-33, Maness Spring 2011
CPSU-MANESS-S11S12G33
3 Members
7 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 9
All Time: 2,907
