Olympus D590 Motherboard Replacement
  1. Olympus D590 Motherboard Replacement, Face Plate: step 1, image 1 of 1
    • Remove five baseplate screws using a Phillips #00 screwdriver.
  2. Olympus D590 Motherboard Replacement: step 2, image 1 of 1
    Tool used on this step:
    Buy
    • Press and slide the battery cover retainer clip to the left. Use tweezers to lift the battery cover away.
  3. Olympus D590 Motherboard Replacement: step 3, image 1 of 1
    • Remove the single screw from the battery housing using a Phillips #00 screwdriver.
  4. Olympus D590 Motherboard Replacement: step 4, image 1 of 1
    • Using tweezers, lift the rubber plate to expose the ports.
  5. Olympus D590 Motherboard Replacement: step 5, image 1 of 1
    • Remove two screws from the ports using a Phillips #00 screwdriver.
  6. Olympus D590 Motherboard Replacement: step 6, image 1 of 1
    • Use a spudger to pry the faceplate away from the rest of the camera.
  7. Olympus D590 Motherboard Replacement: step 7, image 1 of 1
    • To avoid disconnection of the connector line to the motherboard, use caution when pulling faceplate away from camera case.
    • Damage to the connector line will prevent the on/off power switch's operational function.
  8. Olympus D590 Motherboard Replacement, Motherboard: step 8, image 1 of 1
    • Remove four screws holding the motherboard to the internal housing component using a Phillips #1 screwdriver.
  9. Olympus D590 Motherboard Replacement: step 9, image 1 of 1
    • Be cautious of the wires attached to the motherboard.
    • Remove the motherboard from the internal housing component.
    • Do not completely lift the motherboard out with the wiring connected. The wires must be disconnected before proceeding. The next step will demonstrate disconnection process.
  10. Olympus D590 Motherboard Replacement: step 10, image 1 of 3 Olympus D590 Motherboard Replacement: step 10, image 2 of 3 Olympus D590 Motherboard Replacement: step 10, image 3 of 3
    Buy
    • Use rounded tweezers to disconnect the three wiring strips from the motherboard.
    • Using sharp tweezers may tear wiring tape and wires.
    • Use gentle force when wiggling or pulling wiring tape and wires to disconnect from the motherboard.
2 other people completed this guide.
Sara
84 Reputation
2 Guides authored
Cal Poly, Team 28-23, Regan Spring 2010 Member of Cal Poly, Team 28-23, Regan Spring 2010
CPSU-REGAN-S10S28G23
4 Members
14 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 8
All Time: 1,791
