Introduction
If your camera does not have an SD card or your SD card no longer has any memory in it, then it will need to be replaced. Use this guide to ensure you are properly removing and replacing your SD card into your camera. Make sure your SD card is compatible with the Olympus OM-D E-M10 II before you begin.
Olympus has a compatibility table for SD / SDHC / SDXC memory cards can be found here...
Open the battery door latch by moving the black button in the direction of the arrow, towards the camera screen.
Find the SD card located near the hinges of the door and gently press down on it so that it becomes free.
To add your new SD card to your device, follow these instructions in reverse order.
