Olympus Pen E-PL7 Back Case Replacement
  1. Olympus Pen E-PL7 Back Case Replacement, Back Case: step 1, image 1 of 1
    • Use a Phillips #00 screwdriver to remove the six 2 mm screws on the bottom of the camera.
  2. Olympus Pen E-PL7 Back Case Replacement: step 2, image 1 of 1
    • Remove the two 4 mm reverse threaded Phillips screws from the bottom of the camera.
    • Reverse threaded screws tighten counter clockwise and loosen clockwise.
  3. Olympus Pen E-PL7 Back Case Replacement: step 3, image 1 of 1
    • Remove the two 4 mm Phillips screws under the HDMI port cover.
  4. Olympus Pen E-PL7 Back Case Replacement: step 4, image 1 of 1
    • Use a Phillips #00 screwdriver to remove the 5 mm screw near the left hand grip.
  5. Olympus Pen E-PL7 Back Case Replacement: step 5, image 1 of 1
    • Use a Phillips #00 screwdriver to remove the 5 mm screw near the right hand grip.
  6. Olympus Pen E-PL7 Back Case Replacement: step 6, image 1 of 1
    • Flip open the LCD.
    • Use a Phillips #00 screwdriver to remove the 2 mm screw beneath the LCD assembly.
  7. Olympus Pen E-PL7 Back Case Replacement: step 7, image 1 of 1
    • Use a Phillips #00 screwdriver to remove the four 6.3 mm screws from the lens mount.
  8. Olympus Pen E-PL7 Back Case Replacement: step 8, image 1 of 1
    Tool used on this step:
    Buy
  9. Olympus Pen E-PL7 Back Case Replacement: step 9, image 1 of 1
    • Use tweezers to remove the inner metal ring.
  10. Olympus Pen E-PL7 Back Case Replacement: step 10, image 1 of 2 Olympus Pen E-PL7 Back Case Replacement: step 10, image 2 of 2
    • Use tweezers to remove the two springs lying beneath the inner metal ring.
  11. Olympus Pen E-PL7 Back Case Replacement: step 11, image 1 of 1
    • Use a Phillips #00 screwdriver to remove the three 5 mm screws.
  12. Olympus Pen E-PL7 Back Case Replacement: step 12, image 1 of 1
    • Remove the two 4 mm Phillips screws.
  13. Olympus Pen E-PL7 Back Case Replacement: step 13, image 1 of 3 Olympus Pen E-PL7 Back Case Replacement: step 13, image 2 of 3 Olympus Pen E-PL7 Back Case Replacement: step 13, image 3 of 3
    • Press and hold the lens release button while using tweezers to remove the lens hook.
    • Use tweezers to remove the spring underneath the lens hook.
  14. Olympus Pen E-PL7 Back Case Replacement: step 14, image 1 of 3 Olympus Pen E-PL7 Back Case Replacement: step 14, image 2 of 3 Olympus Pen E-PL7 Back Case Replacement: step 14, image 3 of 3
    • Use tweezers to remove the metal clip from the external flash mount.
  15. Olympus Pen E-PL7 Back Case Replacement: step 15, image 1 of 1
    • Use a Phillips #00 screwdriver to remove the four 4 mm screws from the external flash port.
  16. Olympus Pen E-PL7 Back Case Replacement: step 16, image 1 of 2 Olympus Pen E-PL7 Back Case Replacement: step 16, image 2 of 2
    • Remove the second external flash clip with tweezers.
  17. Olympus Pen E-PL7 Back Case Replacement: step 17, image 1 of 2 Olympus Pen E-PL7 Back Case Replacement: step 17, image 2 of 2
    • Remove the external flash port casing to expose five more screws.
  18. Olympus Pen E-PL7 Back Case Replacement: step 18, image 1 of 1
    • Use a Phillips #00 screwdriver to remove the two 6.4 mm screws.
    • Remove the 2 mm Phillips screw.
  19. Olympus Pen E-PL7 Back Case Replacement: step 19, image 1 of 1
    • Remove the two 3.8 mm Phillips screws from the sides of the external flash connector.
  20. Olympus Pen E-PL7 Back Case Replacement: step 20, image 1 of 1
    • Gently pull the back case away from the camera.
    • Do not attempt to remove the back case, as it is attached to the camera by a ribbon cable.
  21. Olympus Pen E-PL7 Back Case Replacement: step 21, image 1 of 3 Olympus Pen E-PL7 Back Case Replacement: step 21, image 2 of 3 Olympus Pen E-PL7 Back Case Replacement: step 21, image 3 of 3
    • To remove the ribbon holding the back case to the camera, use the pointed end of a spudger to flip back the top bar on top of the ZIF connector.
  22. Olympus Pen E-PL7 Back Case Replacement: step 22, image 1 of 3 Olympus Pen E-PL7 Back Case Replacement: step 22, image 2 of 3 Olympus Pen E-PL7 Back Case Replacement: step 22, image 3 of 3
    • Use tweezers to pull the ribbon out of the connector.
    • Remove the back case.
3 other people completed this guide.
Kelsea Weber
20,015 Reputation
32 Guides authored
iFixit Member of iFixit
Staff
141 Members
17,903 Guides authored
One Comment
Loads of screws that don’t need to be removed just to remove the rear case.
Omit step 3,
Omit steps 6 to 13
Omit step 18
Take great care not to pull on ribbon cables
Rod Heeley - Reply
Past 24 Hours: 0
Past 7 Days: 16
Past 30 Days: 37
All Time: 3,312
