Olympus Pen E-PL7 Lens Assembly Replacement
  1. Olympus Pen E-PL7 Lens Assembly Replacement, Battery: step 1, image 1 of 2 Olympus Pen E-PL7 Lens Assembly Replacement, Battery: step 1, image 2 of 2
    • Turn the camera upside down.
    • Push the grey tab to the right to open the battery compartment.
    • Pull out the battery.
    • The battery is not shown in these photos.
  2. Olympus Pen E-PL7 Lens Assembly Replacement, Lens Assembly: step 2, image 1 of 2 Olympus Pen E-PL7 Lens Assembly Replacement, Lens Assembly: step 2, image 2 of 2
    Tool used on this step:
    Buy
    • Use a Phillips #00 screwdriver to remove the four 6.3 mm screws from the lens mount.
    • Remove the lens mount with tweezers.
  3. Olympus Pen E-PL7 Lens Assembly Replacement: step 3, image 1 of 1
    • Use tweezers to remove the inner metal ring.
  4. Olympus Pen E-PL7 Lens Assembly Replacement: step 4, image 1 of 2 Olympus Pen E-PL7 Lens Assembly Replacement: step 4, image 2 of 2
    • Use tweezers to remove the two springs lying beneath the inner metal ring.
  5. Olympus Pen E-PL7 Lens Assembly Replacement: step 5, image 1 of 2 Olympus Pen E-PL7 Lens Assembly Replacement: step 5, image 2 of 2
    • Use a Phillips #00 screwdriver to remove the three 5 mm screws.
    • Remove the two 4 mm Phillips screws.
  6. Olympus Pen E-PL7 Lens Assembly Replacement: step 6, image 1 of 3 Olympus Pen E-PL7 Lens Assembly Replacement: step 6, image 2 of 3 Olympus Pen E-PL7 Lens Assembly Replacement: step 6, image 3 of 3
    • Press and hold the lens release button while using tweezers to remove the lens hook.
    • Use tweezers to remove the spring underneath the lens hook.
To reassemble your camera, follow these instructions in reverse order.
2 other people completed this guide.
Kelsea Weber
20,015 Reputation
32 Guides authored
iFixit Member of iFixit
Staff
141 Members
17,903 Guides authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 6
Past 30 Days: 20
All Time: 2,079
