Olympus SP-320 Back casing and LCD screen Replacement
  1. Olympus SP-320 Back casing and LCD screen Replacement, Back casing and LCD screen: step 1, image 1 of 3 Olympus SP-320 Back casing and LCD screen Replacement, Back casing and LCD screen: step 1, image 2 of 3 Olympus SP-320 Back casing and LCD screen Replacement, Back casing and LCD screen: step 1, image 3 of 3
    • Remove the 3 mm long screws with a Phillips head screwdriver that has a PH000 size bit.
  2. Olympus SP-320 Back casing and LCD screen Replacement: step 2, image 1 of 1
    • Remove the 3 mm long screw using Phillips head screwdriver that has a PH000 size bit.
  3. Olympus SP-320 Back casing and LCD screen Replacement: step 3, image 1 of 1
    • Pry the outer case open using a blue, plastic opening tool.
    • Pry case open gently to avoid tearing the ribbon that connects the front part of the case to the back of the case.
  4. Olympus SP-320 Back casing and LCD screen Replacement: step 4, image 1 of 3 Olympus SP-320 Back casing and LCD screen Replacement: step 4, image 2 of 3 Olympus SP-320 Back casing and LCD screen Replacement: step 4, image 3 of 3
    • Detach camera body from back casing and LCD screen.
    • Pull gently on the white connecting cable to detach it from the main body of the camera.
    • Lift the small, plastic clip, detaching the ribbon from the main body of the camera.
  5. Olympus SP-320 Back casing and LCD screen Replacement: step 5, image 1 of 3 Olympus SP-320 Back casing and LCD screen Replacement: step 5, image 2 of 3 Olympus SP-320 Back casing and LCD screen Replacement: step 5, image 3 of 3
    • You have detached the back casing and LCD screen.
One Comment
Is that thin white connector - a powercable to screen led-light? thnx
Alex CalmCroft Tokarsky - Reply
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 9
All Time: 536
