Olympus SZ-12 LCD Screen Replacement
  1. Olympus SZ-12 LCD Screen Replacement, Back Case: step 1, image 1 of 2 Olympus SZ-12 LCD Screen Replacement, Back Case: step 1, image 2 of 2
    • Remove nine 4.45mm Phillips #000 screws from the outside of the case.
  2. Olympus SZ-12 LCD Screen Replacement: step 2, image 1 of 1
    • There are four screws to take out on the bottom of the camera.
  3. Olympus SZ-12 LCD Screen Replacement: step 3, image 1 of 1
    • There are three screws to take out on this side.
  4. Olympus SZ-12 LCD Screen Replacement: step 4, image 1 of 1
    • There is one screw to take out on this side.
  5. Olympus SZ-12 LCD Screen Replacement: step 5, image 1 of 1
    • There is one hidden screw inside the HDMI port.
  6. Olympus SZ-12 LCD Screen Replacement: step 6, image 1 of 1
    • Using the blue plastic opening tool, wedge open and remove the case.
  7. Olympus SZ-12 LCD Screen Replacement, LCD Screen: step 7, image 1 of 1
    • Once you have the back case off, remove the LCD Screen.
  8. Olympus SZ-12 LCD Screen Replacement: step 8, image 1 of 1
    • Using a plastic opening tool, gently lift the retaining flap on the display cable ZIF connector.
    • Pull the display cable from its socket on the motherboard.
  9. Olympus SZ-12 LCD Screen Replacement: step 9, image 1 of 1
    • Remove the LCD screen from the device.
    • Be careful not to rip the display's ribbon cable as you pull the screen away from the device.
0 Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 14
All Time: 579
