Olympus Stylus 1030 SW Camera Lens Replacement
  1. Olympus Stylus 1030 SW Camera Lens Replacement, Olympus Stylus 1030 SW Camera Disassembly: step 1, image 1 of 3 Olympus Stylus 1030 SW Camera Lens Replacement, Olympus Stylus 1030 SW Camera Disassembly: step 1, image 2 of 3 Olympus Stylus 1030 SW Camera Lens Replacement, Olympus Stylus 1030 SW Camera Disassembly: step 1, image 3 of 3
    • Using the iFixit Opening Tool, pry off the plastic part of the lens.
    • Using the T6 Torx screwdriver, unscrew the three screws.
  2. Olympus Stylus 1030 SW Camera Lens Replacement: step 2, image 1 of 3 Olympus Stylus 1030 SW Camera Lens Replacement: step 2, image 2 of 3 Olympus Stylus 1030 SW Camera Lens Replacement: step 2, image 3 of 3
    Tool used on this step:
    Buy
    • Using the Phillips #00 screwdriver, unscrew the three screws.
    • Carefully swivel the metal cover out towards you.
    • Using tweezers, remove the metal washer.
  3. Olympus Stylus 1030 SW Camera Lens Replacement: step 3, image 1 of 2 Olympus Stylus 1030 SW Camera Lens Replacement: step 3, image 2 of 2
    • Using the tweezers, slowly peel off the plate.
  4. Olympus Stylus 1030 SW Camera Lens Replacement: step 4, image 1 of 3 Olympus Stylus 1030 SW Camera Lens Replacement: step 4, image 2 of 3 Olympus Stylus 1030 SW Camera Lens Replacement: step 4, image 3 of 3
    • Using the Phillips #00 screwdriver, unscrew the two screws on the side of the camera.
  5. Olympus Stylus 1030 SW Camera Lens Replacement: step 5, image 1 of 3 Olympus Stylus 1030 SW Camera Lens Replacement: step 5, image 2 of 3 Olympus Stylus 1030 SW Camera Lens Replacement: step 5, image 3 of 3
    • On the opposite side, use the Phillips #00 screwdriver to unscrew both screws.
    • Take out the speaker plate.
    • Open the multi-connector cover and slide off the side panel.
  6. Olympus Stylus 1030 SW Camera Lens Replacement: step 6, image 1 of 3 Olympus Stylus 1030 SW Camera Lens Replacement: step 6, image 2 of 3 Olympus Stylus 1030 SW Camera Lens Replacement: step 6, image 3 of 3
    • Using the Phillips #00 screwdriver, unscrew the screw above the speaker.
    • On the bottom side of the camera, unscrew the two screws.
  7. Olympus Stylus 1030 SW Camera Lens Replacement: step 7, image 1 of 3 Olympus Stylus 1030 SW Camera Lens Replacement: step 7, image 2 of 3 Olympus Stylus 1030 SW Camera Lens Replacement: step 7, image 3 of 3
    • Open the battery compartment cover.
    • Use the Phillips #00 screwdriver to unscrew the screw in the battery compartment.
  8. Olympus Stylus 1030 SW Camera Lens Replacement: step 8, image 1 of 3 Olympus Stylus 1030 SW Camera Lens Replacement: step 8, image 2 of 3 Olympus Stylus 1030 SW Camera Lens Replacement: step 8, image 3 of 3
    • On the front of the camera, unscrew the two screws shown.
    • Gently pull on the side until the camera is separated from the back panel.
    • Remove the shutter and power button.
  9. Olympus Stylus 1030 SW Camera Lens Replacement: step 9, image 1 of 3 Olympus Stylus 1030 SW Camera Lens Replacement: step 9, image 2 of 3 Olympus Stylus 1030 SW Camera Lens Replacement: step 9, image 3 of 3
    • Use the Phillips #00 screwdriver to unscrew the four screws on the front of the camera.
    • Unscrew the shutter using the Phillips #00 screwdriver.
  10. Olympus Stylus 1030 SW Camera Lens Replacement: step 10, image 1 of 2 Olympus Stylus 1030 SW Camera Lens Replacement: step 10, image 2 of 2
    • Release the top holding using a spudger.
    • Slowly and carefully separate the front and back of the camera, exposing the electrical ribbons.
  11. Olympus Stylus 1030 SW Camera Lens Replacement: step 11, image 1 of 3 Olympus Stylus 1030 SW Camera Lens Replacement: step 11, image 2 of 3 Olympus Stylus 1030 SW Camera Lens Replacement: step 11, image 3 of 3
    • Using the spudger and tweezers if needed, remove the ribbons from the computer chips.
  12. Olympus Stylus 1030 SW Camera Lens Replacement, Camera Lens: step 12, image 1 of 3 Olympus Stylus 1030 SW Camera Lens Replacement, Camera Lens: step 12, image 2 of 3 Olympus Stylus 1030 SW Camera Lens Replacement, Camera Lens: step 12, image 3 of 3
    Buy
    • Peel off the black tape using tweezers.
    • Unscrew the 1.0 cm screw.
    • Use the spudger to carefully take out the lens compartment.
  13. Olympus Stylus 1030 SW Camera Lens Replacement: step 13, image 1 of 2 Olympus Stylus 1030 SW Camera Lens Replacement: step 13, image 2 of 2
    • Carefully take out the lens and the black plastic pieces along with it.
  14. Olympus Stylus 1030 SW Camera Lens Replacement: step 14, image 1 of 3 Olympus Stylus 1030 SW Camera Lens Replacement: step 14, image 2 of 3 Olympus Stylus 1030 SW Camera Lens Replacement: step 14, image 3 of 3
    • Unscrew the three screws found on top of the mirror lens.
    • The mirror lens can now be removed.
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 14
All Time: 1,181
