Olympus Stylus 1030 SW Rear Case Replacement
  1. Olympus Stylus 1030 SW Rear Case Replacement, Rear Case: step 1, image 1 of 3 Olympus Stylus 1030 SW Rear Case Replacement, Rear Case: step 1, image 2 of 3 Olympus Stylus 1030 SW Rear Case Replacement, Rear Case: step 1, image 3 of 3
    • Start by removing the front case of the Olympus Stylus 1030 SW.
    • Use a Phillips #00 screwdriver to unscrew the three screws.
    • Once all three screws are removed, take your hand to remove the front case from the camera. You will lift until it is fully off.
  2. Olympus Stylus 1030 SW Rear Case Replacement: step 2, image 1 of 3 Olympus Stylus 1030 SW Rear Case Replacement: step 2, image 2 of 3 Olympus Stylus 1030 SW Rear Case Replacement: step 2, image 3 of 3
    • Use a Phillips #00 screwdriver to remove the screws from the side panel.
    • Use a Phillips #00 screwdriver to remove both of the screws from the battery door.
  3. Olympus Stylus 1030 SW Rear Case Replacement: step 3, image 1 of 2 Olympus Stylus 1030 SW Rear Case Replacement: step 3, image 2 of 2
    • Flip the Olympus Stylus 1030 SW camera upside down, the rear side facing away from you.
    • Use a Phillips #00 screwdriver to remove both screws.
  4. Olympus Stylus 1030 SW Rear Case Replacement: step 4, image 1 of 2 Olympus Stylus 1030 SW Rear Case Replacement: step 4, image 2 of 2
    • Now flip your camera with the rear side facing away from you. Remove both Phillips #00 screws.
    • You should now be able to remove the front case.
  5. Olympus Stylus 1030 SW Rear Case Replacement: step 5, image 1 of 3 Olympus Stylus 1030 SW Rear Case Replacement: step 5, image 2 of 3 Olympus Stylus 1030 SW Rear Case Replacement: step 5, image 3 of 3
    • To remove the rear case of the camera, start with the rear end facing away from you.
    • Remove the two Phillips #00 screws.
    • Then flip the camera to the front facing you.
    • Remove the single Phillips #0 screw.
  6. Olympus Stylus 1030 SW Rear Case Replacement: step 6, image 1 of 3 Olympus Stylus 1030 SW Rear Case Replacement: step 6, image 2 of 3 Olympus Stylus 1030 SW Rear Case Replacement: step 6, image 3 of 3
    • Now place your camera right side up with the front facing you.
    • Open the battery door and locate the screw placed in the middle.
    • Remove the Phillips #00 screw.
    • You now take your spatula to separate the rear case from the camera.
Alexis Sulzle
301 Reputation
2 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 75
